cd changer
cd changer
Are there any venders that fix fix cd changers,Mine stopped working after I changed batt.IT WAS WORKING UNTIL i Changed batt.I did reset button and it sees cd,won't see when I hit aux button.
Is your new battery fully charged? Try turning radio off, disconnect battery for a few seconds, reconnect and then turn radio on. Also try removing cartridge and then re insert. Changing a battery should not cause changer to go bad. Also pull codes. It might give you a clue to what happened.
Received 19,743 Likes
'20-'21-'22-'23-'24
Doesn't make sense that a change of battery would cause the CD changer to quit working.
