Radioflyer's Bi-xenon ACA headlights Available again
#163
What's the contact info for Radioflyer? I don't know if I'll be able to reach anyone on a Sunday afternoon but my hid low beams are inop. Input to ballast has battery voltage when the switch is on but no lights. High beams work though. If I turn the stalk the lights won't come up but if I push for brights, the lights will pop up and close normally if I turn the switch. The only thing I can think of would be bad ballasts? But what are the odds of both being bad? I can't think of a way to test the output...all fuses check out.
#164
I'm installing as we speak. Turns out the HID inputs are reversed. If you look at the wires, the tan output wire for low beam should be connected to the "+" side of ballast input side. If you need further help, PM me.
oharal (10-12-2015)
#167
#168
That's what I had to do...I never ever would have noticed the little molded in markings for +/-...did you guys get lucky and notice that or did you know it was coming somehow?
#169
The following 2 users liked this post by Tuscany:
PreciousChud (10-12-2015),
TXWMH (10-12-2015)
#170
Supporting Vendor
#172
Supporting Vendor
The instructions said as much.
And all things considered, I don't think the wait time was bad at all, especially once you got everything together.
Thanks again!
#176
I have a couple of questions.
I can figure out what the HIDs do when the high beams are on, but are there LEDs in the high beam location? is that part of the $650 kit?
What is the weight difference between the factory setup and this?
#178
Not fully sure, but they seemed similar to me. New ones may be a tad lighter (pun intended?).
#179
Supporting Vendor
Batch 2 thread here:
https://www.corvetteforum.com/forums...post1590686855
Our kit is slightly heavier than factory (shipping weight is about 8 lbs) compared to the parts being replaced which are about 3 pounds.
#180
I came in here looking for these. Thanks!
Mine arrived today. I didn't do anything but open the box and take a look but I appreciate the quality you've put into these things.
Thanks again!
Thanks again!
