Hello i have a friend with a c5z and he wants to get ccw c15's 18x13 and put 335 30 18 ps2's on them. Will they fit on a Z without having to do anything. Thanks
I've seen that size on an 18x11.5 wheel with stock fenders on a Z06 and it fit just fine. Tire bulged a little but nothing crazy. An 18x13 WILL stick out no matter what the offset is. Not enough room on the inside to fit that much wheel without sticking out.
I do not have a Z so not sure if they are the same in this area. But I do have 18X11.5 and have 335/30/18 and they don't stick out much. I can take a picture if you want.
They are about the same, except Zs have a bit less room behind the wheel due to the rear brake ducts
What if he were to do a 18x12 with 335's would that stick out?
