C5 Vert vs Z06
#41
Just FYI my 01' 6speed convertible says 3146 on my registration, I think that's pretty light considering its a 1SC with every option except ride control. It also has non runflat Michelin pilot sports with no tps and c6 z06 shocks and sways all around a CAI and a Mangaflow x and catback so it's even lighter then stock....
eDIT: then again maybe my heavy chrome Z06 wheels even every thing out
#43
Also, if I plan on doing suspension, is there any purpose of looking for the ride control?
Targa top doesn't fix the fact that I still have to get out, take care of the top and pull it off completely... I know, not much more work than a vert, but that's one reason I don't touch my t-tops often.
Although, can't beat the look of a targa vette imo
#44
If you're looking at a car with adjustable ride, I wouldn't turn it down, but I would definitely consider it a negative.
There will be some people who say they like it, but if you're looking to mod the car, its probably something to avoid.
#45
NO. The adjustable ride control (option F55) is a pain in the butt if you do any sort of suspension/brakes/wheels modification, not to mention the replacement shocks are really expensive, and its a hassle to disable or remove the system.
I'll avoid that at all costs then because I will be upgrading suspension.
#46
My Volant CAI, C6 Z06 shocks and sways were just swapped out, my Mangaflow magnapack was swapped and welded at an exhaust shop for $100. Although it's not the first thing I would do depending on the mileage of the car my 01' had about 90kmi on it back in August and the shocks were squeaking and pretty much shot, when I changed them to the C6 Z06 stuff it felt like a new car and the handling was signifantly improved..lowered on stock bolts also..definite mods to do.
#48
You may be right, but when I checked out verts, it seemed like a lot of latching, unlatching, lifting, tucking, closing, etc. to go from up to down. The targa takes less than a minute to remove, and two minutes to put on. More importantly, when the top is up the car feels and sounds like a coupe, and not a rattling creeking ragtop. But that's just my 2 cents brother. The convertible looks fantastic with the top DOWN!
#49
#50
After owning both I can assure you it's definitely easier and quicker dropping the top in a C5 vert then removing the roof and storing the top in a C5 coupe, yes the Coupe is a little quieter with the roofs on but it's not by a lot and the vert is actually quieter with the tops down because there's less wind buffeting and squeaks..
What does a ZO6 have over a base model? Different heads, cam, lighter exhaust, different body panels to cool the brakes better? Problem with the ZO6, it still is not a Convertible! I can do plenty of mods to my car to make it like a ZO6 if I wanted to, but I don't road race the thing, I just cruise in it to enjoy it. Already have two race cars, don't need more.
OP, do what you want to, it's your time and money, enjoy it!
#51
Your comment confirms why the coupe was the better choice for me. I drove an MGB in high school and with the top up I felt disconnected from my surroundings. So much so that I emded up removing it entirely one summer...but only because "it never rains in Southern California"
#52
I have read awhile back that c5z does use the extra chassis support that convertibles use thats why Zs tend to handle so great put a side the suspension differences. Weight wise C5s are not heavy and c5z did have to use some extra tricks to loose weight due to the extra chassis stiffness added.
#53
I'll have to check them out!
Any reason you had to lower the seat?
That's a fair assessment! I kind of feel the same about WS6's, I don't like the thought of my buddies WS6 vert being fast, as opposed to a t-top car.. but again it's all preference.
I just think something about being able to be out in the elements and then deciding I want to put the top up would be something cool and different for my next car.. and I'm going to keep my WS6, so I can always go back to that for a 'hard-top' car of sorts.
