[Z06] Looking for 475 at the wheels
HI everyone, well 4 years ago I traded my CE zo6 in for a family vehicle and I am now retired and back home where I want to be, I picked up a very very nice black/mod red 2001 Z this past spring and I really like the car and want to keep it rather then setting goals on a C6Z.
I am looking for a Head, Cam, Intake, and Long Tube Header Package that puts more torque and HP to the ground then a stock C6Z.
Looking for a package that sounds fantastic!!!
I am also looking to have some things done to the clutch and rear end to support the extra power for an everyday driver. Any other recomendations are appreciated.
Also, it would help to find an installer and tuner within a days drive for me.
Here is a video of what I want my C5 run like. I want in to run like the Blue C6 Z in the video. Maybe some of you know what the car in the video is running
Cruise-In IX Veteran
Unless you are considering nitrous or forced induction you will need a maxed out setup. You will have to do all the bolts ons, FAST intake, larger TB, decent sized cam and a good set of ported heads.
Received 1,261 Likes
you might also consider a tr6060 conversion if you want it to run like the c6z in that video due to different gearing and it is a lot stronger than the c5 setups to boot... I considered staying n/a and doing what you're thinking of but all that work to barely edge out a STOCK c6z would make me feel kinda sad after all the effort haha... and once you're done that's pretty much it, no room for improvement unless you build another motor
I've been down the path of heads/cam to put down a little more than a stock c6 z06. I am now taking the cam out, putting a blower cam and ECS kit on. I should have done this from the start. The price difference isn't even that much higher for a blower.
My advice is blower.
That being said if you don't want a blower then call up Martin@Tick, PatG, <insert other well known cam designers> and talk to them about what you want. Make sure you get exactly what you want.
Off the top of my head
- Ported or Aftermarket heads
- Cam
- Timing chain
- Balancer
- Pushrods
- Lifters
- Lifter trays
- Cam swap gasket kit
- Fast 92
- LS2 TB
- LS2 Adapter harness
- Fast intake manifold gaskets
- 1 7/8" headers
- Catch can
- Tune
- Intake (if you don't have one already)
- New belts
- Oil Pump
Received 1,679 Likes
Toque is running the AFR 205's, G5X1E, Fast 92/92 with all the goodies and is making 480ish @ the wheels... It can be done! He has been running this combo foras long as I have known him w NO issues... His car is FAST! I am sure he will chime in and correct me if I mis spoke.
My setup made 470/416. TSP 233/239 on 112lsa, FAST 102/102, PRC 215's w/ 60cc combustion chambers, ARH 1.75s', with their pipe and stock Ti's, SLP UDP, and LS7 lifters.
I would opt for a Supercharger.
You will not get quite a much torque off the line, but by the time you spend everything you will need to get this kind of power to the wheels, might as go with a SC.
If you want the SC to kick in from off idle to redline, might want to look at the Edlebrock SC and the Ligenfelter adapter kit for the C5. Eldlebrock uses a roots blower.
Of course you could do it with headers, cam, and nitrous shot as well.
that white car needs a driver mod ... How fast is the C6Z running at the track? Looks like it just had street tires on and was playing with the C5.
I think my stock bottom H/C/I could take it
I just found the video on you tube and has been one of my favorites because I know that C6 runs very good n/a in order to be able to take on a S/C like that and I want my C5Z to run and sound just like that.
Really interested in that LG kit. A mail in tune can be purchased from them
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
I looked at all the different options and price wise, the cost of going all N/A and gaining HP/TQ is pretty expensive ..lol, so I started to research S/C setup's and the ability to build lots of power fast is insane, I opted for a ECS kit, and I love it...runs amazing well I have over 625 hp at the crank and the car is a beast, best of all it still drive's like stock until I hit that go pedal and it becomes a whole different car!
Ok, thank you guys so much for all the replys. I see that N/A power is very expensive.
Can you guys help me put together a package that will not involve changing the cam?
I REALLY want all the grunt and torque off the line that I can get affordably and want it to sound very very good with a longtube header package
I was thinking long tube headers, intake, heads, and a clutch. Also will have the tech perform the TSB on replacing the oil control rings. Do any of yous have a link for that GM TSB on the 2001 oil control rings?
What do ya's think?
What do ya's think?
Supercharged C5 Z06 Vs. Cammed C6 Z06 - YouTube
1. because the factory M12 trans gearing is to steep.
2. The HP/TQ curve is so much larger and wider on a LS7
3. Its a LS7 lol...
No doubt @ 475whp the LS6 will put a whooping on 95% of anything you will encounter on the street and it will pull like a champ...
