Irritated beyond belief: Service Column Lock
#41
Okay, so after all that I put the roof down in preparation for the long test drive. When I started it up, I got the "pull key, wait 10 seconds" message. I did so while I forced myself not to contemplate suicide. About 15 seconds later, started right up, no issues. I tested by going back and forth in the driveway to make sure it wouldn't crap out. I then drove 74 miles over 2-1/2 hours, but dared not shut it off (even while I had to wait for a draw bridge). Got home, shut it down, restarted, no issues. Thoughts?
Called Richard at Compliance and he confirmed my car, (2000 automatic) probably was one of the small minority that needed the extra step in the install procedure. BTW, kudos to Richard, great customer service!
There are instructions on I believe page 2 to replace the green wire on the large connector with the brown wire from the LMC5, then cut the little brown wire loop (second brown wire) that comes out of the LMC5. So today I did the above step, put it back together and spent the better part of the afternoon/evening on a 100 mile tour, stopping and starting a bunch of times with no issues. All fixed
