Red engine covers
Red engine covers
I have the red engine covers and wanting to put red covers on my washer tank and the overflow tank any body know the name of these red is it torch red.
Received 2,677 Likes
2018 C5 of Year Finalist
I purchased my Torch Red fuel rail covers from forum vendor RPI designs. I wanted to brighten up my engine bay and wanted a little pop contrast against my MSG paint.
If you're trying to match up the OEM Z06 red fuel rail covers, note that the Torch Red is a lot brighter and has a glossier finish. Below is a picture of my set up for reference. Good luck!
Received 1,674 Likes
More than likely they're torch red.
Received 3,812 Likes
St. Jude Donor '03-'04
there is a big difference between the Zo6 red molded in fuel rail covers, and
and Torch red fuel rail covers.
Torch red is the factory color name
many vendors use factory paint codes to paint fuel rail covers.
the after market painted fuel rail covers and accessories are usually factory paint codes.
I originally did my fuel rail covers with a non factory red color...close to torch but not torch.
Then I felt a bit Nostalgic, so I did them in the Original Chevy orange that was used on 60's Chevy engine blocks.
My real question is, what's that screen/pierced-metal widget over the alternator?
Former Vendor
As to the pierced-metal widget alternator cover, it's the ACC stainless steel cover powdercoated black from DD Mods.
A couple more shots...
Received 19,282 Likes
'20-'21-'22-'23-'24
The stock fuel rail covers look nothing like the torch red color on the body of the car. If you want to add torch red covers to the fluid tanks under the hood, that would be a great time to have a good body shop sand down and paint the stock fuel rail covers torch red. It would look great.
Location: Obama says I'm a bitter white guy clinging to my guns and religon and he's right
