c5 troublespots and mileage
Looking at buying a early c5 (97-99). For a car that looks like it has been well maintained what are some trouble spots I should look for on a car over 100K miles. Also if it was well maintained how many miles should I expect out of the engine before major maintenance. Thanks been vetteless for 10 years boy off to school time for fun again
Received 19,289 Likes
'20-'21-'22-'23-'24
Browse through the below thread - lots of good info in it.
http://forums.corvetteforum.com/c5-g...ion-files.html
St. Jude Donor '15, '17
I bought my '98 last year and it has been a great car. Being 16 years old though, it has had to have few things replaced since I bought it. The a/c compressor went and while they were doing that I also had them replace the water pump, hoses, thermostat, belts, plugs and wires, tension pulleys, service tranny and rear end. I also installed new rotors and pads. If you are looking at higher mileage, see how much work has been done, get receipts, and check car fax. I bought mine right so the investment that I have put into it is just that.
That thread shows a Youtube vid of retrieving the codes. Use that when you're checking out a car
The LS motors were designed to go to 200k. Many owners have that and more on them with no issues
