air dams!! iso
air dams!! iso
along side the air dam is a black piece that helps air flow ! im searching for it ! connects to nose and fender black plastic ! do not know what it is called !
Received 1,674 Likes
I too see them on e-Bay all the time.
Received 19,285 Likes
'20-'21-'22-'23-'24
Check with vendors like CorvetteMods or gmpartshouse. They should have them.
i have the three piece air dam im looking for ? black piece that connects to front bumper and keeps water and air moving? if you can look under your c5 it will be behind the three piece air dam in front of tires ? have no idea what this is called ! tks
bolts where the 3 piece air dam bolts! but where the outside two pieces bolt !!! ????????????tks
