New radio, no sound from speakers
Hey I am in the process if putting in a new kenwood screen in my 99 frc.
Currently everything is wired correctly but I am not getting any sound from the speakers the diagram shows two wires running to 25v capacitors. Those wires are not connected to anything currently where do I run these too?
Received 3,812 Likes
St. Jude Donor '03-'04
Yes I have the after market wire harness.
However. There are multiple harnesses in the back of the factory radio. One for power one for speakers and one for antenna, the radio functions, But I just can't seem to get any power to the speakers. I will post the diagram before the end of the night and show you where I'm stuck at
I just did an install on my 02 with a Pioneer SPH DA02 AppRadio. I used Peripheral's GMAH wiring harness and couldn't get any sound, either. In a last ditch effort, I hooked it up without the harness, tapped power from fuse 22 in the floorboard fuse box, and miraculously I had sound!
What harness are you using?
So the diagram posted, everything on the output side is connected correctly, everything on the input side is correct it's the last image, where wires are running from the unit to the speakers I'm unsure of where I tap into. Are the capacitors on the diagram built into the factory Bose speakers?
Former Vendor
your using the wrong harness in the peripheral lsve61
you need this
http://shop.doubledmods.com/searchqu...ords=roem-vet1
you need this
you need this
you need this
Dennis is an absolute expert when it comes to audio installations. It just goes to show that Dennis is more than willing to help you even though you did not buy your head unit from him... Had you bought from him, the unit would have come already wired with the correct GM adapter, so all you had to do was plug the existing harness from your car into the one on the new head unit that Dennis provide. When I bought my head unit from Dennis. it took me less than 1 minute to plug and play the unit.. I not talking about the installation just the connections. All the wires from the adapter where cleanly connected as if it came from the factory that way.
That's a very clean looking install Mr. ET
OP best of luck getting her firing on all cylinders, I'm sure you'll get it now that your aware of the problem.
Hey guys if it's going to make my life easier I'll buy one from Dennis no doubt.
However I'm curious as to how it will not work? I'm sure you guys are more electronically savvy then I, but it seems a bit crude for a business to produce a wiring harness with a corvette wiring diagram only to have it be non compatible? No?
Former Vendor
not a radio replacement harness which you need if you are indeed replacing the head unit and trying to retain the stock speakers
For example, I received more personal service and assistance from Dennis when I needed to replace my door speakers, a purchase of under $150, than I did when I walked into what was then my new bank with a check for $100,000 that I wanted to open a new account with.
Without a doubt, any (and I do mean any) stereo-related needs I have in the future will go first and last to Dennis. The way he handles himself during his normal routine and day-to-day operations won my loyalty, which is not an easy thing to do. I can't think of any other company that I can say the same thing about.
He'll be getting my radio bezel sometime in the near future to convert into a double-din, and when he does I will also be buying a new head unit to go along with it. Business earned because Dennis treated my $150 problem like I was going to hand him a $100,000 check.
Dennis is the ultimate expert. I bought my double din dash replacement and stereo from him and it works perfectly. Follow what he says and you're good to go.
Just don't try getting Dennis to expand to New York!
Jeff
Jeff
