Very important A/C info
On a previous thread I told about the work it took to R&R my A/C compressor which involved removing my supercharger. Anyway, it was warrantied by the auto parts store and I remembered they wanted me to flush the system and also R&R the evaporator/dryer so it was something I knew to do to keep the warranty for 2 years. But never did they require the Condenser to be replaced, hence the flush kit. BUT I decided to youtube to see about flushing the condenser cause I suspected contamination from the original condenser made the new A/C compressor fail. BINGO.....I learned a lot and now know the reason for the failure. I installed a NEW condenser and complete A/C system so I hope to never have it fail again(at least for a number of years) LESSON LEARNED!
Now I have ICE COLD AIR!
Watch the video about the condenser's I learned why flushing IS a waste of time, just buy NEW!
wow, Interesting… so basically if you have a compressor go bad you really need to replace the rest of the system at the same time you replace the compressor.
Received 19,302 Likes
'20-'21-'22-'23-'24
Thanks, Rick. That's some good info.
I still did all the work and charged my own system......but did it the right way and replaced ALL the components so no contamination destroys the new compressor. Use the Flush kit to clean out your A/C lines.
So remember,
A/C Compressor
Dryer/Evaporator
Condenser
Orifice tube
Flush Kit
2 cans Freon
1 can Pag 150 oil
= ICE COLD AIR!
It's going to run about $600-$800(Oreilly Auto Parts) for parts alone...toss in a few hours of labor which should push it to $1000 or abouts!
Received 3,812 Likes
Yes....I used to think why spend all that money and how silly it was for the repair shops to charge soo much for a simple a/c compressor job. I even worked at the dealerships and wouldn't listen to the A/C technicians and thought it was just a way to inflate the profits. But after trying to keep the costs down and doing it myself...I learned a valuable lesson from being cheap and just doing the minimum. NOW I realize the error of my way and seen the actual costs of doing the least I could.
So remember,
A/C Compressor
Dryer/Evaporator
Condenser
Orifice tube
Flush Kit
2 cans Freon
1 can Pag 150 oil
= ICE COLD AIR!
So remember,
A/C Compressor
Dryer/Evaporator
Condenser
Orifice tube
Flush Kit
2 cans Freon
1 can Pag 150 oil
= ICE COLD AIR!
You are already saving money by doing the job yourself.
Nothing like doing it right the first time and counting the money you save from not having to do it again. Actually I would have thought it would have cost quite a bit more than that to replace everything.
AS we know there are many knowledgeable people on this forum. There are also many who " think " they know something because they change their own oil and have a few tools. Or their grandfather worked in a gas station in the 50's and that's how he does it.
Guys willing to experiment with alternatives and offer their findings help as long as their findings are honest and they have the ability to know the difference between hype and fact.
For me, I had millions of dollars worth of test equipment and data on areas I was involved with. I laugh sometimes when a guy with a few wire ties and a fender cover tries to compete with GM Factory design engineering.
There are lots of areas of the Corvette I know very little about its development so I don't offer the same expert advice I do in areas that I am an absolute expert.
I once was asked to be an "Expert" on a Federal court in a case of Liability about a vehicle I helped designed, but I refused to be named an "Expert" and would ONLY give testimony on the areas I actually designed.
Thanks Bill for trying to help those who really want to listen and learn about these great cars!
One of 6 prototypes I built and helped design....certainly not a sports car!
Received 3,866 Likes
2015 C5 of the Year Winner
Thanks for all the info and the video. I will definitely keep this in mind when I need to change mine out.
