FYI ceramic brake pads.
Received 2,675 Likes
2018 C5 of Year Finalist
I'm also intalling a set of Baer Eradispeed +2 rotors and per earlier threads and ET's input and secondary proof of his show-car rotors, the OEM GM AC Delco semi-metallics don't stain the rotors. I'm not sure if Hawk pads, with their ferro carbon material, will stain the rotors like ceramics do.
I have an older set of Baer Eradispeed rotors in the original sizes currently installed on my 2004 vert. At the time of installation, the shop talked me into a set of GM Ceramic pads because I was sold at the time on the "less dust is better" model. Personally, I've never liked the feel, but I've lived with it. It feels more like a grinding than stopping and they do squeak at times. Mostly on very hot Florida summer days, that's why I'm looking forward to returning to semi-metallic. Now the question is which semi-metallic.
BTW, anyone looking for OEM GM AC Delco semi-metallic pads, shop around online. I've seen price differences of $150 for a full set ranging between $120 and $270!
While we're talking brakes (Sorry Rick, don't mean to hijack), I appreciate any advice on choosing my SS braided hose kit. Please see this thread...
http://forums.corvetteforum.com/c5-g...questions.html
Most ceramic pads work fine on these cars for street use. The pedal feel is terrible and you have to press down harder but your actual stopping distance isn't going to change.
Tires will affect your stopping distance more than anything in a C5.
I ran Carbotech 1521's in my C5. They are a ceramic base but don't feel like it and they do stop the car very well on the street.
The other advantage is what little dust there is is pale gray and non-corrosive so the don't tear up your wheels. I have a set for the C7 I'm putting in this week.
Highly recommended.
Highly recommended.
Supporting Vendor
St. Jude Donor '11,'13
Highly recommended.
Highly recommended.
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
F $140 R $121
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
I have Hawk ceramic pads on my 04 Z all around ..The feel just not right ..Around town Ok but at a little speed ..no... has Low dust for sure that's nice .. Have run HPSs big dust and right the dust is bad for paint and gets all over the place but will stop ... These pads are new not happy with them looking for something else ..I guess wil have to deal with the BLACK dust I guess would be better that a clean wrecked 04...
I definitely have this approach with my battery as I'm on my second AC Delco battery in 10 years with no issues. I replaced the first one after seven, trouble-free years just because I felt I needed to and didn't want to take a chance on 8 years in the Florida heat.
With cars that have ABS, the tires don't play a role in stopping unless it's on slick pavement.
I prefer to STOP THE CAR not to have the wheels look pretty
The semi-metallic pads don't fade after hard braking and DO stop the car when a panic stop is involved. If you drive at 30 MPH and put no miles on the car go for ceramic. If you drive it like you stole it go for SM and just clean the wheels occasionally.
The California Mini Dash Duster works fantastic for cleaning up brake dust on CCW wheels!
Yes, the stopping distance will most definitely change when compared to a semi-metallic pad. If you have proof otherwise please post it, otherwise this statement does not hold up to the many studies done on the topic.
In fact, being able to engage ABS is what makes pads and rotors irrelevant.
ET,
I was under the impression after reading what lots of experts had to say that braking distance on a single panic stop of a given car was limited by the grip of the tires. So long as there's enough clamping force to lock the wheels, braking distance should not change with different pads, larger rotors, etc. I've read lots of articles in magazines as well as online articles and even an SAE journal article, that have made this claim.
Just wondering if you can provide an explanation why ceramic would yield a longer braking distance on a single stop?
If we're taking about repetitive stops where brake temp, fade, and etc plays a factor then for sure I'd agree that ceramic is not the way to go, and most articles back that up as well.
#34
You absolutely do not have to push down harder on the pedal for braking. You either don't know what you are talking about, or your's were installed incorrectly. If you've ever even driven a Corvette, with both kinds of pads....
They (ceramic pads) are quiet, and stop just fine, for street use. Reduction in brake dust is significant.
Don
#35
http://www.tirerack.com/tires/tests/...y.jsp?ttid=177
Max performance summers doing 78.6-79.1 feet:
http://www.tirerack.com/tires/tests/...y.jsp?ttid=174
and Extreme summers 74.5-77.2 feet:
http://www.tirerack.com/tires/tests/...y.jsp?ttid=172
All on the same car and same pavement during the same summer, unfortunately Tire Rack doesn't test tires across performance categories on the same day so it's not 100% apples to apples.
I can't find any test data on brake pads except this one quickly:
http://blog.caranddriver.com/perform...c-yellowstuff/
It doesn't apply to street driving though as they're averaging multiple back to back 100 mph stops. Even with that, the 4 pads start out very close in the first cycle which is the only cycle that is even close to relevant for a street car. Notice, though, that the required pedal force varies WAY more than the actual stopping distance. The high-friction HP+ requires as little as 12 lbs to do a .5g stop and the lower friction overheated HPS in later cycles takes 24 lbs to do the same. Double the pedal force yet the panic-stopping distance is only 2.7% longer.
The metallics feeling better at light to moderate loads does NOT mean they perform any better in a street ABS panic stop.
#36
I have had good ceramic pads and bad ones. (for both stopping and for dust)
I have had good semi-metallic pads and bad ones. (for both stopping and for dust)
I was responsible for an automobile manufacturer's brakes about 20 years ago. At that time ceramics were quite new (or at least not as common) and were not as good. The materials science in brake pads was changing rapidly then and I expect it has continued. I suspect that the ceramics now are much better than they were then. The ceramic used in pads can be as low as about 4% of the pad material. It is used as the structure for the pad, but the ceramic is not the only material in the pad that provides the friction.
There have been statements about the coefficient of friction, but I do not see them published for comparisons. The general pad friction grading (required to be on the edge of the pad) is so crude as to be ineffective in comparisons except to weed out the real junk.
Many of the worst graded pads are semi-metallic. Many of the pads used for racing are semi-metallic.
I have seen some ceramic pads perform better than OEM semi-metallic pads (for both stopping and for dust)
My point is that it is not a blanket statement to say the semi-metallic pads stop better than ceramic pads or vice-versa.
#37
Part of my concern is that the GM OEM ceramic pads can stain Baer Eradispeed rotors. Since part of the attraction of these rotors is the bling they provide in addition to the improved performance, I want to keep the rotors looking as good as they perform. I don't mind the additional brake dust if the pads perform well and don't discolor my rotors, pit my polished wheels or damage my paint.
#38
This does not include the pads we're talking about, the GM semi-metallics. The article is only about aftermarket pads.
#40
Tires most definitely play a role in stopping distance. A friend did a BBK on his 350z, and his stopping distance was identical to stock brakes after. If your brakes are strong enough to lock up the wheels, adding more brake power will do nothing to help. It's just like traction, if you can't get traction until 4th gear, adding more power isn't gonna help your 1/4 mile time at all, better tires will.
