C5 Corvette Nexus 7 tablet install (Build Thread)
**UPDATE: I may be interested in selling this entire setup to any interested parties. I am testing the waters on selling my car (http://denver.craigslist.org/cto/4570112382.html for anyone interested). I may sell all this stuff and return it to a single din setup so the buyer doesn't have to worry about the tablet and all the learning curve involved.
If anyone is interested, I would sell the tablet, double din bezel, cables, PC fan for cooling behind the tablet, for $500 shipped + your factory radio bezel. Pretty good deal considering the bezel alone is $280, plus wait time, and the tablet is $270ish.**
Haven't seen anyone do this build on a C5 yet, but... I have. Figured I would put together a thread of all the efforts, headaches, and amazing results from the process here. Let me know if you have any questions.
**WARNING: THIS IS NOT YOUR GRANDMA'S TAPE DECK REPLACEMENT. FOR ADVANCED INSTALL/MODIFICATION ENTHUSIASTS ONLY**
Keep reading if you want to know more.
Parts:
Nexus 7 2013 32gb
(NOTE: unlocked, rooted, and running ElementalX kernel, and Cyanogenmod11 ROM)
Pioneer DEHX9600BHS single din head unit (
Double D Mods double din radio bezel (http://shop.doubledmods.com/C5-Corve...n-Bezel_c2.htm)
VGate ELM327 OBD2 Bluetooth Adapter ( ) (Bluetooth PIN is: '1234')
OBD2 90 degree extension cable (
Metra 40-GM20 antenna adapter ( )
(NOTE: I haven't set up these antennas yet, and I think I'm missing a piece, or the extension may be of the wrong male/female coordination, so don't quote me on this yet. I will update this when I get around to setting this part up)
Metra 204-inch antenna extension cable (
Micro USB OTG cable (
(NOTE: This is only necessary if you want to have an external connection to the tablet while still charging it. i.e. External hard drive, access VIA your Laptop for updating software, etc. Otherwise, just use a normal USB micro cable for charging)
Infinity 6.5" speakers for the front doors (
120mm PC fan (Not installed yet, for cooling behind the tablet) (
USAMS dual USB adapter (
I had an old 10" Infinity sub, MTX amp, 4 channel amp for door speakers, and wiring kit laying around, so I can't provide part numbers on that. There is some random stuff that is not mentioned that I had laying around such as MDF board for creating a bracket for the door speakers, etc. (Do a search for build threads on those)
I'm only running front speakers at the moment. Rear speakers will be installed in a couple of weeks, but that's a bit irrelevant to this build thread, as that is a very basic stereo item/install.
**DISCLAIMER** Time for a little rant about this before you get too excited and decide to do this yourself. This project has taken a LONG time, and has been extremely difficult. Would I do it again? I don't know, to be honest. It's really been a long road, but I really am THRILLED with the final result. Hopefully this thread can help some people hoping to do the same thing avoid some hassles and headaches that I could have avoided had I found something similar to this already done with a C5.
With that out of the way, here's how everything happened. I started out by ordering my Nexus 7 tablet, and trying to modify my radio bezel myself. Trust me when I say this, unless you've done body work/etc. before, don't bother. Just send it to Dennis/Double D Mods, and let them do it. They did an incredible job on my bezel. Dennis and Donna, they were AMAZING to work with. Really a great couple of people to talk to. Originally, I think there was a misunderstanding of what I was wanting, and they thought a completely new design would be needed, but alas, I told them to just go ahead and send me a normal double din bezel with dual gauge cluster built in, and got it a week or so later (they had it for a couple of months while figuring out how it would need built - again, a bit of a misunderstanding, no one's fault). The build quality was incredible, and I would highly suggest them! If you replicate my build, just get a normal double din bezel. A Nexus 7 WILL FIT without modifying the bezel, even though I was told it would not (this goes back to my belief that there was a miscommunication on what I was wanting).
When you get your bezel back, you will see a flat back surface. You have a couple of options, here. You can figure out a mounting system of some sort, or epoxy/hot glue the tablet in place, or go the ghetto way like I am currently doing until I figure out how I want to permanently mount the tablet and have it be removable, and use industrial strength electrical tape (I'm actually okay with how it's mounted for now).
Some photos of the tablet sitting against the bezel. Note: I put some industrial grade electrical tape against the flat sides to act as padding/reduce vibrations/avoid scratching. It works great, and is not visible when installed:
How I have it mounted for now is just some electrical tape strapping it in from the top to the bottom in three strips, one left, one right, one middle. Yes, it's kind of ghetto, but it works for now until I figure out a permanent quick-disconnect mounting system. The black tape is barely noticeable, and actually could be entirely concealed with some creativity. NOTE: From Double-D Mods, there is a gap on the top and bottom of the tablet. You can use some felt strips to "fill" the gap, or not. I opted not to for now, as I'm going to chalk the gaps off to being vents to let heat escape from the center area behind the bezel. You will also need to follow the double din install on Double D Mod's website as normal, which is to drop the HVAC controls a bit (pretty easy), and remove the lower mounting tray (pretty easy as well). See their website for additional info.
Onto the single din head unit. I removed the entire factory Bose stereo setup. Speakers, head unit, and CD changer (everything has been sold already, sorry). NOTE: I tried mounting the single din in the glove box, but it WILL NOT WORK!!! There is part of the firewall behind the plastic box/frame that will be in the way. I had to think of an alternate solution. This literally was just thought of last weekend, so it's still a new idea, and it may get changed down the road. For now, it's sitting behind my passenger seat in the trunk area. I am building a carpeted MDF box for it this weekend to conceal it, so it will be much cleaner than this when completed:
This head unit serves as my central unit for sending audio to the amps/speakers. I tether an internet connection to the Nexus 7 from my Android phone, and I connect the tablet VIA Bluetooth to the head unit for audio. It works PRETTY good, but I have a couple of issues with Bluetooth needing to be cycled after sitting for longer than several minutes with no connection from my tablet. Not a deal killer for me.
The tablet has so much you can do with it that I'll have to get into that later on, as I feel like I'm already rambling on and on, and my fingers are getting tired. I'll save that for another day, but the important thing that you all will be interested in is an app called Torque. This app is phenomenal. You can monitor just about anything important in your computer, check codes, clear codes, and soooo so so much more.
There's a plugin I like that is rather neat. RacingMeter for Torque (https://play.google.com/store/apps/d...meterfortorque). It allows you to have a realtime racing dash right in your center console. It's pretty awesome, and VERY customizeable. Very cool for us track folks.
Some advantages to doing this:
- in-dash GPS via Google Maps
- Huge music and entertainment library via Spotify, Pandora, external HDD library, etc.
- aesthetically incredible looking
- highly customizeable
- in-dash code scanner/sensor monitoring
- in-dash gauge setups
- in-dash internet browsing (when parked, or stuck at a train, etc. of course)
- in-dash email/text
- hands free calling/caller ID
- ability to add rear-view camera setup (I have not done this yet, coming soon...)
- Much MUCH more
Some Disadvantages:
- No **** for volume control, not a big deal to me, though. Volume control are the Corvette flags on the main screen seen below. Available widget for distribution upon request.
- Very complicated setup
- Very time consuming
- Very frustrating at times
- Wait time on getting bezel modified (WORTH IT, though)
- A couple of minor bugs, but this was just finished this weekend, so I'll have those ironed out in no time.
Onto the current look of the installation. Again, yes it is electrical taped into place for the time being, and I am missing a gauge in one of the holes (waiting on my new gauge to come in). But, here it is. If you guys have any questions, please ask. I can't wait to read all the negative feedback from people claiming I ruined this car... oh, you silly people. Just enjoy the read, pictures, and have fun with your Corvette!
As it sits today:
(No **** for volume control, not a big deal to me, though. Volume control are the Corvette flags on the main screen seen above. Available widget for distribution upon request.)
Screenshot of the plugin for the digital racing gauges:
Bonus pic of what it's sitting in:
Parts:
Nexus 7 2013 32gb
Amazon.com : Pioneer DEHX9600BHS CD Receiver with Full-Dot LCD Display, MIXTRAX, Bluetooth, HD Radio Tuner, and SiriusXM Ready : Car Electronics
)Double D Mods double din radio bezel (http://shop.doubledmods.com/C5-Corve...n-Bezel_c2.htm)
Amazon.com: Oem OBD-II OBD2 16Pin Male to Female Extension Cable Diagnostic Extender 100cm: Electronics
)Metra 40-GM20 antenna adapter ( )
Amazon.com : Metra 44-EC204 204-Inch Antenna Extension Cable : Vehicle Audio Video Antennas : Car Electronics
)Micro USB OTG cable (
Amazon.com: Micro USB Host OTG Cable with Micro USB Power for Nexus 4 5 7 10 Galaxy Nexus & Samsung Galaxy S 3 III 4 IV 5 V.: Computers & Accessories
)(NOTE: This is only necessary if you want to have an external connection to the tablet while still charging it. i.e. External hard drive, access VIA your Laptop for updating software, etc. Otherwise, just use a normal USB micro cable for charging)
Amazon.com : Infinity Reference 6030cs 6.5-Inch 270-Watt Two-Way Component System : Component Vehicle Speaker Systems : Car Electronics
)120mm PC fan (Not installed yet, for cooling behind the tablet) (
Amazon.com: Enermax T.B. Silence 120mm Ultra Quiet Twister Bearing Cooling Fan, Black UCTB12: Computers & Accessories
)USAMS dual USB adapter (
Amazon.com: USAMS Compact High Output Dual USB Car Charger - 3.1A Output Ideal for Charging iPad, iPad 2, Galaxy, iPhone, HTC, Droid, GPS, and Other Tablets, Smart Phones and USB Powered Devices (Data cable not included) (black): Everything Else
)I had an old 10" Infinity sub, MTX amp, 4 channel amp for door speakers, and wiring kit laying around, so I can't provide part numbers on that. There is some random stuff that is not mentioned that I had laying around such as MDF board for creating a bracket for the door speakers, etc. (Do a search for build threads on those)
- Much MUCH more
Some Disadvantages:
As it sits today:
ArmchairArchitect (02-17-2017)
(Additional Info Parking Space 1)
I was using an AutoMeter dual gauge pillar for my gauges until I got my bezel modified with the dual bezel. I am now selling it to anyone who may be interested. Holes are already drilled to ensure proper alignment, and will include 4 new plastic mounting pins. Black in color, brand new condition. $60 shipped anywhere in the US.
Moderator
very nice... if I outgrow my pioneer deck, I may consider doing this.
One question -- how do you turn on the nexus? the power is on the side, which looks like it would be covered up by the DD bezel. does the Cyanogenmod includes a "doubletap power" or something?
The power and volume buttons are indeed concealed by the bezel, and therefore inaccessible when installed. A friend of mine modifies the power buttons on these to be able to have an external button (under the kick panel, etc. wherever, really). The volume buttons will be inaccessible, but he can modify the Vol-Down button as well to enable external access to recovery. Not the easiest solution, but it IS A SOLUTION!
ElementalX DOES have the ability to DT2W (double tap to wake/knock knock/etc.). However, I will be disabling that, as it's been causing issues with the upper menu slide actions.
For power on/off, I use an app called Tasker, which watches for PowerOn/PowerOff conditions, and applies tasks such as Enable Wifi/Enable Bluetooth, etc. on poweron, and Disable Wifi/Disable Bluetooth, Enable Airplane Mode/etc. on poweroff. There are a few bugs I'm still ironing out, but I almost have it figured out completely.
The elementalX kernel allows for fastcharge mode, which I haven't really seen it charging very quickly, yet. I noticed last night a 8% power drop just sitting. This is without forcing any apps closed, or anything, and with Bluetooth re-enabling itself (another bug I'm working on). Not that terrible, really. The problem is, in the 15 minutes it took me to drive to work, I only got about 4-5% charge BACK. So, needless to say, I have some figuring out to do, but I'll have it squared away any day now.
Moderator
Ah! Excellent question, and I was just getting ready to modify one of my additional posts with some software/powering info, as that has been a bit of a challenge.
OR, just keep the charger to an "always on" connection.
The draw from the nexus is pretty small, and will not really impact your battery. And once it's fully charged, it will stop drawing.
What kind of charger are you using? you can get a 1amp (I think even 1.5 amp) 12volt charger that should fairly quickly.
I'm fairly confident the power is being limited somewhere, not in the software. I'm just not quite sure where yet, though.
I considered doing something similar to what you said, and in tasker adding a failsafe condition to where it will charge up to 95~%, and then not charge again until it reaches >60% or so. That would ensure it's not constantly charging, I would think. But, with the issues we have with power draw on C5's was concerning me with getting into the car with a dead battery one day. I have a brand new battery, but I can't risk it since this is my daily driver. Although, I seem to recall seeing somewhere that the power draw issues were related to the Bose system, so I may not have that happening anymore with all that removed now.
Very Cool! I am planning on doing something very similar.
Very clean looking install! I like how it turned out.
I'm planning on using a 1/2 DIN Equalizer in my install, it will be able to fit in the dash below the tablet and has volume ****, bass control, etc.
Moderator
why not just use the on-screen eq?
Cool setup. I was thinking of doing something similar, but believe I'll be going this route instead:
Kenwood ddx8901hd with screen mirroring my phone via MHL cable.
GundamX7X (10-11-2017)
Received 19,472 Likes
'20-'21-'22-'23-'24
Very cool. Subscribed to this thread.
Tablets and phones don't have separate sub controls.
The 1/2 din eq is quicker to use and you don't need to take your eyes off the road.
Also having a separate sub level and crossover control is much better than fiddling with the screen while driving.
On my Note 2 it's a pain getting to the sound adjust screen and the external eq gives you a lot more you can do.
Received 3,369 Likes
2023 C6 of the Year Winner - Modified
mindblown right now... expecially when i looked up the cost of the tablet in question... the temptation to pull out my credit card right now is bad... highly considering this route. Awesome job!
Yeah, the tablet is a lot less than a double din, but the overall cost all said and done was probably as cheap as an entry level double din (if not more), though those don't have the customization like the tablet, no GPS, etc., so it's worth it, considering.
