[Z06] Tire size on 19 inch rear
I am looking into switching to an 18 front 19 rear what size tires seems to fit the best 02 Z06 stock height.
265/35-18|295/30-19 is the standard +1 size. A lot of guys do a 305/30-19 to get some more rubber out back. I had 255/40-18|295/35-19, which filled the wheelwell gap better, offered more ground clearance, and allowed more speed in each gear when I bought my car, but you'd have to retune it or your speedo would be off if you did anything but the first combo I mentioned.
How is the speedometer re-calibrated with the 305 on the back? I'm considering that option. Thanks.
You could also fix it with one of the handhelds, but that's a lot of money for not a lot of results
so would i
but
19x10 puts him in an odd postion
295 30 19 would likely fit, especially in a more narrow tire like the s04
if it was a 10.5" wheel like the tsw's you could use a wider 295 30 19 like the pss or a narrow 305 like the hankook v12
if the front is 18x9 you use 265 35 18, if it's 9.5 you could use 275 35 18 if you have 305 out back
but
That looks great! No rubbing, no issues with AH and they don't stick out of the fender openings, right? Thanks for posting! Looks like the rears are on backorder right now. :-(
