Oil Pressure sender
I couldn't do it on a 2001 following the video. There was an extra pipe or something running across the opening that I couldn't get around that wasn't shown in the video.
oil sender
I just did mine 2 weeks ago using the video as a guide. I used hemostats and a piece of rubber hose to guide the new sensor in. The key is getting the proper socket. I got mine from advance auto parts it is very thin and has two sizes 1 1/16 and 1 inch and its 3/8 drive, it gives you more room than 1/2 inch drive . I got the old one out and the new one in using the same socket....bend a coat hange to pull the connector. I took me 1/2 hour.....
And if you do remove the intake install a oil señor reelection kit while you have it off, and that will make it a 5 minute jib next time the sensor goes bad. Sensor are known to go bad quite often.
Thats how I would do it if I had the plastic intake manifold. With a supercharger, its a PITA to lift off. Might be worth trying this with a SC. Or as some has done, take the cowl cover off, hole saw a hole to take it out, and then the cowl cover will cover up the hole.
