MGW shifter shorter than stock?
2017 Corvette of Year Finalist
2016 C5 of the Year
My question is the MGW shifter shorter height wise than the stock C5 shifter? I ask because i just installed the C6 shifter for the C5 and its noticeably taller than the stock shifter. Its almost to tall but to to bad. I just ordered the MGW and im hoping its shorter height wise than the stock C5 shifter. I already know the throws are shorter just hoping the handle height is shorter. Thanks for the help.
Pro Mechanic
I don't remember if you can make it longer than stock, but you can definitely make it shorter. About 30% shorter if I remember correctly.
Great, positive shifts...recommend anti-venom mod with 1 washer.
I run the TPS 427X C5/C6 short throw shifter on mine. It's very short and it has an angle to it. I also did the Anti-Venom mod. Adding the shifter was one of my most favorite mods that I have done to my C5 Z06 so far.
Stock vs TPS shifter comparison:
I have the b m ripper now and it's very notchy. It's almost hard to shift but I don't have anything to compare it to other than stock. I love the really short throw. Do you do much driving around town or racing? Also where can I find of these? I assume I can throw my hurst ball on this?
The Hurst **** should fit. This is the thread from which I purchased mine from a while back. Not sure if they're still running this deal or not but you can give it a shot.
http://forums.corvetteforum.com/c5-g...-shipping.html
