For Gawd's sake, would someone please make a 305/35/18 or 315/35/18 street tires!
It's truly baffled me for years.
With the amount of Mustangs, Camaros, Vettes, Classic Muscle-cars, etc running around with 18x10, 18x10.5, 18x11, 18x11.5, and 18x12 rims, why hasn't any tire manufacturer ever come out with a 305/35/18 or 315/35/18 tires?
The 295/35/18 is a great size and fits the 18x10 and 18x10.5 rims squarely, but it starts to look pretty narrow on anything above 18x10.5.
Then we have the 315/30/18 which is absolutely not an option because it is too short at only 25.4". Some guys run it but I've always thought it looks unacceptable on the rear of our cars, especially given that the OEM 295-35-18 measures 26.1"
And then your only option is to jump over to a bloated 335/30/18 which is too wide for most applications. Typically requires you to lose the brake cooling plastic on the inside and creates horrendous rubbing on the inside of the wheel-well when going up driveways (when using typical c5 offsets).
Why hasn't there been a brand to come forth and capture this market? If someone offered a 305/35/18 or a 315/35/18 I would buy today.
Rant over.
Rant over.
Rant over.
Rant over.
If they made them they would be on my car already.
http://www.tirerack.com/tires/tires....num=035ZR8R888
http://www.americanmuscle.com/nitto-...305-35-18.html
Those Toyos autocross tires won't last long
There are getting to be a lot of sizes not made anymore and a lot with very few choices. Not just this size, but a lot of the 15, 16, and 17 sizes for older Corvettes are just not around any more. Choices for even the stock sizes for C5's especially Z06's are getting limited.
It would seem like when there are no choices on these sizes it would become profitable for a manufacturer to make some limited runs occasionally. I suspect that there could be a market. I think that is what some of the reproduction makers like Coker have found out.
Pro Mechanic
Just been through this painful experience myself.
Wanted some really high peformance street tires for a car that is not a DD, rarely if ever sees rain and is not a track car. Just love to carve corners when I can.
Wound up with Nitto NT-05's on OEM Z-06 wheels. 275/40ZR17 and 295/35ZR18. http://www.nittotire.com/Tire/Street/nt05
Would have loved a 305 in the back with the same aspect ratio, but just doesn't exist in a street tire.
Toyo Makes a 315/35/18 TQ Drag radial, but it is a stiff sidewall radial like a regular street tire. It has full tread and drives pretty good in the rain.. Damn sure handles 10x better then a Nitto 555R in the curves..
About as close as you're gonna get to a regular street tire in a 315/35/18... These are my DD tires.. Cheap too at $260 each
Received 1,870 Likes
19" tires were once the most expensive sizing but that's no longer the case. Nitto offers 19" rear tires in 295,305,315,325,335,and 345's.
Just have to pick the right size for your application.
Poor selection in 17"s is the main reason I switched to 19"s. 18" sizing isn't too bad,,yet.
Received 2,054 Likes
