Help nitrous ZEX dry kit
Old 05-13-2014, 01:12 PM
EvilLs1
EvilLs1's Avatar
Default Help nitrous ZEX dry kit
Hi I bought a used ZEX dry nitrous kit and I need help I need to know where to connect the intake and the regulator hoses to my stock ls1 ? Also if I need to connect the nozzle before or after the MAF sensor ? Plz help I need to finished the install by Sunday... Stock air filter tubing.
Old 05-13-2014, 01:14 PM
Todd157k
Banned Scam/Spammer
Todd157k's Avatar
Most of the N2o boys hang out at LS1tech. On a dry kit, you put it in front of the MAF.
Old 05-13-2014, 01:18 PM
EvilLs1
EvilLs1's Avatar
Ok thanks. Those it have to be away so many inches from it?? Or it don't matter?
Old 05-13-2014, 01:21 PM
Todd157k
Banned Scam/Spammer
Todd157k's Avatar
I had mine about 4-5 in away. you want a nice pattern but not too wide as it hits the maf wire. Also, LS1, remove the screen. Careful not to f up the little wire in the middle.
Old 05-13-2014, 01:25 PM
EvilLs1
EvilLs1's Avatar
Ok kool. So u saying to removed the screen inside the MAF?? Well that be better wit the n2o??
Old 05-13-2014, 01:32 PM
Todd157k
Banned Scam/Spammer
Todd157k's Avatar
yes. the screen on the maf. yes, works better.
Old 05-13-2014, 06:05 PM
EvilLs1
EvilLs1's Avatar
Just eliminated the screen. But do u know where to connect the intake and regulator hoses to from the zex box to the manifold ?
Old 05-13-2014, 06:30 PM
mrr23
mrr23's Avatar
St. Jude Donor '15
i wonder what would happen if you called zex and asked them for the instructions???
http://www.zex.com/
PHONE: 1-888-817-1008
as far as hooking up the regulator line, that won't happen as the fuel pressure regulator has no vacuum line going to it.
i found this basic instruction sheet from zex online pretty easily
http://news.compperformance.com/Instructions/ZEX109.pdf
Old 05-14-2014, 01:15 PM
EvilLs1
EvilLs1's Avatar
http://www.zex.com/
I called ZEX and they said they don't make the dry kit for vettes because they have no fuel return line... So I can't use this kit on my vette. Only the wet ZEX kit..
Old 05-15-2014, 08:23 PM
Todd157k
Banned Scam/Spammer
Todd157k's Avatar
ok.. we need to step back here a little. I'm getting the feeling that you have not done any of this before. There's a LOT of things to do looooong before you get to push the button.
You can use a dry system (like I did) on a vette w/o a fuel return line. You will need larger injectors, a BAP (boost a pump), colder spark plugs, and tuning. You also "should" have some safety stuff like a Fuel pressure safety switch (may be built into the Zex box.. I dunno), first gear cutout switch (manual trans).. and the list goes on and on.
If you can afford to buy another motor, just bolt in their kit and flip the switch. I will be a very fast n furious couple of minutes.
oh.. as for a vacuum line, the only one is on the rear of the intake manifold and almost impossible to get to without taking off the manifold.
Old 05-15-2014, 09:50 PM
mrr23
mrr23's Avatar
St. Jude Donor '15
He won't need larger injectors and a boost a pump unless he is going to run a large out of nitrous. Usually above 125. Tuning is debatable. Stock tune should be no issue.
I know this as I have run thousands of pounds of nitrous In my cars.
The zex kit needs to go.
Old 05-16-2014, 01:45 PM
EvilLs1
EvilLs1's Avatar
I'm goin wit the zex wet kit instead I forgot I had it lol.. I ya e everything set up. But. I need to know wich wire in the tps sensor do I tap into ??
Old 05-16-2014, 01:50 PM
mrr23
mrr23's Avatar
St. Jude Donor '15
I think blue but again calling zex and getting the instructions from them would be much quicker than here.
I found the instruction for you here by doing an Internet search
http://www.rpmoutlet.com/c5zex.htm
Old 05-16-2014, 02:01 PM
mrr23
mrr23's Avatar
St. Jude Donor '15
https://www.corvetteforum.com/c5-for...ml?styleid=140
And a search for tps wiring for a 2000 corvette on here resulted in someone asking this question who was installing a zex kit back in 2005
To Help nitrous ZEX dry kit
Quick Reply: Help nitrous ZEX dry kit
