Best quality flared rear fenders
Who has the best quality, least messing around flared rear fenders for a c5? I want a set that is as close to factory fit as possible.
Thanks all
Marty.
Thanks all
Marty.
With that requirement I would definitely AVOID L5 flares.
Mine required extensive work to fit. Translate that to $$$$$....
Consistency of the quality in their product is non existent.
Also lots of threads about their non existent customer service and less than professional business ethic.
Received 3,812 Likes
St. Jude Donor '03-'04
final fit.
Painted and installed
Rick, thanks for the compliment. You are a design visionary. The Ironic thing about these brake scoops is that " They look like they belong on the car, and the OEM ones look like an after market bolt on. I was just leaving GM when the Z06 was being designed. I know for a fact that not too much thought or design or budget was put into the OEM Z06 scoops. I don't mean any disrespect to anyone choosing to use them. You have already done 40 % of the work on your car to add these to your machine. just remove the Zo6 outer scoop and glass in the BPP scoop. You have gifted hands and time to burn. This is a 1200 dollar upgrade that you could do for about 300 dollars.
Thanks again
Bill
Thanks again
Bill
Received 2,705 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
Sweet!
