[Z06] 10pcm code
10pcm code
throwing this code every once in awhile..a buddy gave me a halltech air filter. all i did was replace it with the stock box.left everything else stock...even my air bridge bellow connection.i have checked all connections everything tight....??
P0101 Mass Air Flow (MAF) System Performance
anybody got any suggestions...i have not tuned the car..its completely stock other than the halltech..
thx for any advice...
- Did you reinstall the MAF in exactly the same location and orientation as it was installed by GM?
- Did you turn it slightly?
- Did yout forget to tighten the band clamps on each end of the MAF?
Yes did same maf location,all tight,tried to put maf exactly same location....clamps tight I will re check again tomorrow.
Thx for ideas.....
Thx for ideas.....
