[Z06] Do 315/30/18 fit on a z06?
Old 04-21-2014, 02:32 PM
DANNYZ0608
DANNYZ0608's Avatar
Default Do 315/30/18 fit on a z06?
Putting on Some new tires and wanted to see how big I can go...looking at some 315/30/18 would they fit?
Old 04-21-2014, 03:17 PM
p1bz
p1bz's Avatar
I run Toyo tq 315/35/18 on my lowered stock rimmed z06. They fit fine, and have descent traction.
Old 04-21-2014, 03:21 PM
envyz06
envyz06's Avatar
depends on your wheel size.
Old 04-21-2014, 04:24 PM
imflyinbiya
imflyinbiya's Avatar
I run the Toyo R888 in 315 on my factory z06 wheels, lowered on longer bolts with no issues.
Old 04-21-2014, 04:48 PM
p1bz
p1bz's Avatar
Really? You don't say?
Old 04-21-2014, 05:13 PM
mikebq
Support Corvetteforum!
mikebq's Avatar
Default 315/30/18
I'm currently running PS2's 315/30/18 on 10.5 wheel which are fine lowered on stance coilovers. Just ordered the same size in toyo R888'S ... you will be fine
Old 04-21-2014, 07:00 PM
DANNYZ0608
DANNYZ0608's Avatar
Thanks guys
Old 04-21-2014, 08:57 PM
GeorgeZNJ
GeorgeZNJ's Avatar
St. Jude Donor '08-'09
315/30/18 michelin pilot sport cup I needed a spacer, kuhmo v710 fit fine, with hoosiers I need a spacer. Hoosiers are racing slicks
Old 04-21-2014, 11:15 PM
apollo240
apollo240's Avatar
Where do you all find these tires? I look on tirerack, discount tire, nitto, bfg, and even toyo website.
Old 04-21-2014, 11:23 PM
troyguitar
troyguitar's Avatar
A lot of big tires in 17/18" sizes have been discontinued over the past few years. The only 315/30/18 street tire available today as far as I know is the BFG Rival... but you'd have to run that at all 4 corners on a C5 since they don't make Rivals in any useful 17" size to pair with it.
Old 04-22-2014, 01:41 AM
NVESTZ06
NVESTZ06's Avatar
SEARCH next time. Jeebus.
Old 04-22-2014, 08:06 AM
aaronc7
aaronc7's Avatar
Stuffing wide and wider low profile tires on a particular wheel width isn't going to give you a whole lot. Sidewall will start to bubble out which does not look good IMO and it negatively affects handling. 295 is stock on the rear wheels... I would go up to 305, but that's about it. Tire specs list their "approved" rim widths limits and their ideal width as well.
Old 04-22-2014, 03:44 PM
p1bz
p1bz's Avatar
While this is true, two manufacturers with the same stated size tires will be actually different, hence this discussion. My Togo 315's are no wider than my M/T 305's. Also, some sidewall BUBBLE will help straightline traction a bit as the tire will give. Which is what most are looking for.
Old 04-23-2014, 10:53 PM
DANNYZ0608
DANNYZ0608's Avatar
I'm putting Hoosier drag radials 315/30/18 you think I will need spacers?
Old 04-23-2014, 11:10 PM
Shad
Shad's Avatar
I run 315/35/18 Toyo TQ Drag Radials on my stock C5 18x10.5" Z06 wheels. I also run them on my 18x11.5 CCW 505a's. I am lowered on stock bolts. No spacers.
To Do 315/30/18 fit on a z06?
Quick Reply: [Z06] Do 315/30/18 fit on a z06?
