[Z06] Went to the dyno
Hope the cam is blower friendly now that you have the bug. Car is beautiful. Looks like mine. I have stopped around 800hp for a while. I need my wife to buy something expensive to justify further mods.
St. Jude Donor '13-'14-'15
It would not be my favorite cam selection to have such a narrow powerband with a split of 60 between HP and TQ---- Looking at your chart-the lines cross about 5300 RPM
So your powerband is between 5300 and 6500-----
-Unless you are consistently running it above 5300 you are losing tons of TQ below that--and that's where races are won
---before 1/2 track----
For example a bone stock C7 has 460 lbs TQ at 4800 !!!That's 70 more than your set up at 500 RPM less !!!!
I would have your tuner shoot for better TQ numbers----HP is just for FORD's and looks nice on paper----LOL
390tq is pretty normal for a cam only 5.7 and when im banging through the gears im not going below 5600rpm... And unless im reading that wrong i have well over 300tq before 3000rpm lol.
It would not be my favorite cam selection to have such a narrow powerband with a split of 60 between HP and TQ---- Looking at your chart-the lines cross about 5300 RPM So your powerband is between 5300 and 6500----- -Unless you are consistently running it above 5300 you are losing tons of TQ below that--and that's where races are won ---before 1/2 track---- For example a bone stock C7 has 460 lbs TQ at 4800 !!!That's 70 more than your set up at 500 RPM less !!!! I would have your tuner shoot for better TQ numbers----HP is just for FORD's and looks nice on paper----LOL
Great #'s btw for cam only. Truth be told I don't known if I've ever seen cam-only numbers that high. What are the cam specs?
I was thinking of getting heads but it made decent numbers with just a cam, so spray and a cai is next on the list
" a top end oriented cam."
Is what you said---... and so did I --only I other words----I said "Unless you are consistently running it above 5300" which means basically the same thing
You can run it and shift way up the RPM band over 5300 in every gear-----BUT 1st !!!
So unless you are prepared t launch it at 5300 RPMs-- 300 ft. lbs of TQ at take-off is sluggish----My opinion form experience---
I never said "top end oriented cam" .... Lol i have 3.90 gears im sure ill do fine at the track, besides this is a low horsepower street car its not a track rat it may make a few passes at the track thats it though.
Looks like it's calling out for a 7k redline. I prefer narrow power bands after growing up racing 2-stroke stuff. The idea of just mashing the throttle in any gear and having the same power is silly to me, might as well buy a damn diesel.
