Font Size..
Font Size..
My pages seem to be bigger than they were. Did I change something or is this something the forum did. The words are bigger. Any advice would be appreciated on this. I have searched and haven't found anything to fix it.
You probably did something on your computer - - the forum is the same.
On some computers, you can hold down the control button on your keyboard and scroll with your mouse wheel - - or click the little washer wheel on the upper right next to the star - - it's your "settings" wheel and you'll see a "zoom" setting - - my guess is that it's above 100% . . . .just dial it back and you should see a return to normal.
Sometimes you might need to reboot your computer. Good luck-
(former Buckeye)
(former Buckeye)
(former Buckeye)
(former Buckeye)
You can do the same thing by holding the control key and hitting + to make the page bigger, or - to make it smaller.
Received 19,219 Likes
'20-'21-'22-'23-'24
Good that you got it solved. I was going to say mine appears the same as always.
