service vehicle light
The first thing to so is to pull the codes. Then ask your question in the tech. Section. There are probably 20 or more possiblities,and 3 to 4 really common ones
You will find many post in the tech section about pulling codes using the dic. You don't need a reader,just your right hand
Received 19,286 Likes
'20-'21-'22-'23-'24
Good advice above. Pull the codes off the DIC and then post them up.
Pull the codes as posted above, then find out what they mean (post 'em here) Have someone write them down as it scrolls through the codes, then we can tell you if it's a serious problem or not. Once you get this information, you can use it in your price negotiations.
Thanks,Matt
