Wiring up an amp? Help
Old 03-11-2014, 09:56 PM
Youngstunta
Cruising
Youngstunta's Avatar
Default Wiring up an amp? Help
Im about to put some subs in my vert and was wondering how others ran their wires. For the power wire that runs from the battery to the amp, where did you fish the wire through or did you drill a hole through the firewall. And how about the ground wire? Thanks
Old 03-11-2014, 10:06 PM
Chilliwack vettes
Chilliwack vettes's Avatar
This is how I ran mine
http://forums.corvetteforum.com/audi...audio-faq.html
Scroll down until you see this 'How do i run a power wire through the firewall?' question complete with pics!
Old 03-12-2014, 09:03 AM
djmlax89
djmlax89's Avatar
I ran a 1/0 gauge power and ground, and found a good spot on the firewall behind the battery to drill through. If you can fit them through the grommet and/or don't want to punch holes, that is a great way as well.
Just make sure you seal it well if you do drill anything, and cover the wires with something to avoid vibrating panels from wearing the shielding off.
Old 03-12-2014, 08:38 PM
PvtJoker21
PvtJoker21's Avatar
Run the wire under the carpet and come out under the passanger seat and ground it to the passanger seat track. Thats how mine is set up
Old 03-12-2014, 08:39 PM
PvtJoker21
PvtJoker21's Avatar
For the power wire, I ran mine under the carpets and threw the foot well of the passanger side to the battery. NO DRILLING REQUIRED!
To Wiring up an amp? Help
Quick Reply: Wiring up an amp? Help
