[Z06] Z06 1st to 4th shift
Old 03-08-2014, 02:55 PM
gnguru
gnguru's Avatar
Default Z06 1st to 4th shift
I have a question. On an '04 Z06 when the 1st to 4th shift light comes on, does that mean it is physically impossible to go to 2nd gear or is it merely a suggestion to go from 1st to 4th? Also, what does the skip shift kit eliminate? Such as the light coming on at all or what else? Thanks
Old 03-08-2014, 03:24 PM
Supercharged111
Supercharged111's Avatar
Try it and see. There's a gate that closes off 2nd and IIRC 3rd gear as well. 1-4 blows at altitude, is doable at sea level. I never tried to manhandle the gates, but if you wait a couple seconds it gives up and lets you grab whatever gear you want. Skip shift kit disables this nanny, but a full tune can do and will do so much more so I wouldn't even screw with the skip shift kit.
Old 03-08-2014, 03:36 PM
skyavonee
skyavonee's Avatar
Yeah, it prevents you from shifting 1-2. One way around it is to double-clutch (shift to neutral, let out clutch, then shift to 2nd). Or just take the RPMs up higher in 1st gear until the light goes out.
A skip-shift eliminator costs ~$25 and can be installed by anyone who can get underneath their car. The light will still come on, but you won't be locked out of gear.
As Supercharged111 mentioned, if you have access to someone with compatible tuning software, they can eliminate both the light and lockout behavior.
Old 03-10-2014, 09:39 AM
roadtramp
Cruising
roadtramp's Avatar
[QUOTE=skyavonee;1586354097]Yeah, it prevents you from shifting 1-2. One way around it is to double-clutch (shift to neutral, let out clutch, then shift to 2nd). Or just take the RPMs up higher in 1st gear until the light goes out.
It depends on the perecentage of throttle being applied, RPM, and speed. Like Skyavonee said, bring RPM's up is the easiest way or push it a little harder. Easy to get around. Was put there to reach fuel milage requirements set by the government at that time I think.
Old 03-10-2014, 09:50 PM
WannaC5Z
WannaC5Z's Avatar
Mine will light up but has never prevented me one bit from shifting to 2nd. Makes me wonder if mine has had the "fix" kit done.
Old 03-10-2014, 09:54 PM
envyz06
envyz06's Avatar
yeah I took my bulb out, drove me nuts. But it doesnt force me into 4th.
Old 03-10-2014, 10:04 PM
rjwz28
rjwz28's Avatar
Yup, sounds like it
Old 03-10-2014, 10:12 PM
momo20
momo20's Avatar
just get your car tuned and they can tune it out...problem solved!
Old 03-10-2014, 10:24 PM
rjwz28
rjwz28's Avatar
To Z06 1st to 4th shift
Quick Reply: [Z06] Z06 1st to 4th shift
