I Need Your Advice
I Need Your Advice
I purchased a 2002 Corvette on Monday with 5,584 original miles. The car is showroom mint. I took it to our local emissions station so I can transfer ownership only to find out the computer isn`t ready or not supported. They told me I had to drive the car and put miles on it so the computer can re-program? We filled the gas tank and went on a 110 mile drive took it back to the emission station and, it failed again. I`m confused. The car is now locked out and I have to take it to a waiver station. I live in Az. So, you guys are very knowledgeable. What is my next step?
My first guess is that the computer wasn't ready. A 2002 should be supported for emissions tests. Any ideas why it wouldn't be ready? Battery disconnected, codes reset, etc.?
Did the technician indicate why it failed the retest? Was it the same reason?
It might be helpful to retrieve and post the DTCs via the DIC. If you aren't familiar with how to do that, take a look at this: http://www.stengel.net/diccodes.htm. For an emissions test, the "P" codes are of particular importance. Also, is the MIL illuminated when the engine is running?
Did you buy the car from an individual or a dealer? Either way, I would go back and ask them for any insight as to why it would fail emissions for the original reason or the subsequent retest failure.
Pull your codes, write them down (make sure you note "H" or "C")
Clear the codes and drive the car for a little while
Before shutting off the engine, pull your codes...compare them to your original list
Post up what you've got and someone on here should be able to help you
BTW...congrats on the new-to-you C5!
Don't let this stumble frustrate you!
For any future issues, always check for DTCs. If you have any, post them in a thread if you need help with an issue. Invariably, someone will ask you to do that anyway...just my 2 cents...
And if you already knew some of this, my apologies...
Hope this helps
Hope this helps
Hope this helps
Hope this helps
I'm fairly certain that all C5s are 50-state legal. Starting in 2001, the emissions sticker under the hood includes "and California", but that is a moot point for the OP. I'm sure a list of your codes will reveal the culprit.
Hope this helps
Hope this helps
HEATED CAT; NOT SUPPORTED
EGR; NOT SUPPORTED
02 SENSOR; READY
HEATED 02; NOT READY
AIR SYSTEM; NOT READY
AIR CONDITIONER; NOT SUPPORTED
CATALYST; READY
EVAP SYSTEM; NOT READY
The OBD2 system is NOT READY as reported by the vehicles on board computer. As I stated, I drove the car approx. 110 miles yesterday and nothing changed. I was told with the low miles the computer has lost its memory due to maybe a low battery and just not being driven enough. In other words, put more miles on it?
Drive it for a while and they should go ready. I use my Actron scanner to get this data from the car so I KNOW it will pass when I go in. You'll have to get below 1/2 tank of gas for the EVAP test to run.
Any time the power is disconnected or ANY CODES CLEARED, the I/M monitors reset.
Get us the codes and we can help. You may have some old H codes that are not really a present issue. It would be great if you could record all the pre existing codes and then clear/remove/reset them. Then drive or at least stat the car and then pull your codes and post what you first pulled and what showed up after clearing them.
For future reference: Many codes will show up as history (H) and not current (C) if you don't pull them while the engine is still running.
DO a search 100's of posts on getting the codes from the DIC on the dash. Not you issue though and if you clear any codes this way, your back at square one. Search on "GM Drive Cycle" to find the EXACT things that will get the I/M's to run (almost impossible to do if your trying just to get them all to run at one drive).
Within 100 or so miles of normal city/highway driving the I'm will run. If your battery is weak, they could be getting reset every time you restart.
BTW, I do have an Actron CP9125 OBDII pocket scanner. But it only read if the engine light is on.
We have a similar testing here. The way i see it, there are two options:
1) Drive the car enough to get the car to read "ready". A car not being ready does not mean there is a problem. Google how to get a car "ready".
2) Get a friend with HP Tuners to change all the parameters that need to set as ready to "read, but do not report", or along those lines.
here you go....
http://forums.corvetteforum.com/c5-g...ion-files.html
here you go....
AO LDCM; B2264H, B2262H, B2284H, B2282H, B2252H, U1064H
A1 RDCM; B2285H, B2283H
A6 SCM; U1255H
I did not clear them. Not sure if I should.
A6 SCM; U1255H
Apparently they are all old codes. I did not erase them. Should I?
http://actron.com/product_detail.php?pid=16298
REMEMBER, you clear ANY codes with the DIC, ALL your I/M's reset!!! The DIC will show much more than the ACTRON will but it will NOT show I/M readiness, your Actron will, SO read the instructions for it.
You can get I/M readiness with what you have, see the 3rd bullet point:
A6 SCM; U1255H
These came up on the on board system. I`m assuming they are HISTORY codes and not current.
