[Z06] C5 Z06 how often do you guys with a vararam
inspect clean the air filter---I only have around 1,000 miles on mine-PITA to inspect it--should I? thx
How is it a PITA? I just got one installed, but it seems like you just unbuckle the housing and pull it out. I had one on my G8 GT and did it every 10,000 miles, it would get real dirty. I would recommend getting a 2nd filter so you can just have one ready to swap in after cleaning the dirty one and letting it dry.
Received 2,061 Likes
Mines hasn't been cleaned in over 25k miles and trapped 127mph last time out at the 1/4
Received 1,261 Likes
I siliconed mine into the upper housing to make sure it had a good seal... the foam gasket they supply is a piece of junk and will deteriorate/warp pretty fast and my filter wouldn't form to the curve of the upper housing on it's own, the silicone fixed that problem... to clean it I just removed the upper housing via the 2 clips and undo it from the silicone coupler and spray it with filter cleaner and rinse with water... I never used filter oil because it can contaminate the maf... had mine that way for about 3 years and it worked fine but I no longer have the need for it anymore
