New From RPI Designs!! C5 Corvette Escort Radar Detector Power Cord
Platinum Supporting Vendor
C6 Corvette CMS Radar Detector Power Cord - Hide your cord!
Tired of the dangling power cords for your favorite radar detector? A little concerned about trying to hardwire a power cord to your fusebox?
Do you have a mirror that has switched power supplied to it for features like auto-dimming, map lights, compass/temperature, or On-Star? If so, this CMS brand cord may just be the solution for you!
If your mirror has these features, chances are the mirror has a wiring harness connected into the back of the mirror housing. My little contraption allows you to quickly connect my power cord right into the harness without any splicing or cutting any wires! You simply push the connectors into the back of the wiring harness to tap in to the proper +12v/ground wires. It is basically a 1 minute install!!!
This is the perfect solution for any Corvette C5 or C6 owner. You can easily attach your Escort Radar Detector right next to the rear view mirror, giving it a perfect view of the road and hidden out of sight without power cables dangling everywhere. The CMS brand cord plugs right into the harness in your rear view mirror. It is very easy to connect and disconnect. Comes with complete installation instructions and your choice of an 8" or 12".
Works with the following:
Escort 9500i, 8500, X50, 7500, 6800, Solo S2
*Valentine V1
*Beltronics STi Driver, Pro RX65, Pro RX55, Vector 995, Vector 965,
*Vector 955,
*Vector 940 (phone style connector), and Express 795
Basically any detector that uses the Escort/V1 Smartcord for power for above brands...
Item # CH-L01 Use coupon code RPIDON5 on phone or on line and receive 5% off the listed price !!
Website Link : http://www.rpidesigns.com/shop/item.aspx?itemid=3359
*Valentine V1
*Vector 955,
__________________
In stock and available here:
Item # CH-L01 Price $14.99 for 8 inch and $18.49 for 12 inch, Use coupon code RPIDON on phone or on line and receive 10% off the listed price !!
Beautiful design.
I made my own using an RJ11 adaptor and can say it's nowhere near as clean as yours. I used uncovered wires to connect it to the rear-view mirror.
Love the fact that you used prongs to connect. I would highly recommend this over making your own.
