My mod thread
Plasti dipped the rear end today. It's a 20 footer...from 20 feet away it looks good. I have experience with plasti dip. The problem is I could not find pin stripe painters tape ANYWHERE. Home Depot, Lowes, auto part stores, Sherwin Williams. I had to buy actual pin stripes for a car. It worked great but damn I couldn't peel it off. It ended up jacking up the edges. I'll look online for actual tape and try again. FML
Today I installed the iSimple from DD Mods. Super easy and works great. I love it.
I also installed a short throw shifter and new ****. It's a universal style ****. I like the way it looks but something isn't quite right. It sits too high, I need to play with it some more.
The shifter has some play. You can twist the shaft side to side about .5". I need to check on that too.
Got the C6 wheels yesterday and had the TPMS switched from the wagons to the new ones. It's still on jack stands until I decide on how to mount the rear wheels. Not sure if I want to use spacers/longer studs or use adapters. Pics will be coming.
The car looks great
You get my PM ?
And that **** your using will sit high, I have one sorta like it and that's just how it is with em.
You get my PM ?
Nice score and good mods to start with!
The Dyno tune will really wake it up too!
Thanks,Matt
Thanks,Matt
Today I hoped to get my vararam installed. Nope. Never even opened the box.
I changed the oil, transmission fluid, rear diff fluid, painted my calipers, and removed the side moldings. All Mobil 1 synthetic.
#33
Received 4,504 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Glad to see you are defiantly having fun!
#34
Congratulations on the new car. It looks nice and getting better.
You have really been busy. Most people make mods over a period of time, but it seems like you have already made a lot of nice mods in the first few weeks you've had it.
Good Job!
#40
