GROUP BUY: VetteNuts C5 Insulation Kit $145 Shipped first 10
Supporting Vendor
St. Jude Donor '11
After many request from members we are going to do a GROUP BUY on the Insulation kits on for the first 10.
Please choose from coupe, Vert or Z06/FRC when ordering, also manual or AT.
615-896-6100
VetteNuts has sold 1000's of these kits are are the same ones featured by Ecklers. We build these in house and this kit has been sold on the forum for years and has been put in all of my Vette's. There is a lot of customer feedback about these kits installed here on the forum.
Here is another great Insulation package from VetteNuts. It is a peel and stick Ensolite IUO insulation material pre installed on top of our Foil Kit. When these two kits are combined together it will come as one kit. Road noise inside your Vette is drastically reduced along with a 10 to 14db drop in cabin noise. We also provide some scrap material for you to use anywhere you like!
The Ensolite was designed by NASA for the space program.This is a very high grade foam/adhesive combination that will handle high heat, is fire retardant just like regular IUO. It resembles a wet suit material. This kit will make a huge difference in heat and road noise while adding only 9lbs to your Vette for both kits.
Vettenuts has sold 1000's of these kits and there is lots of reviews on Corvetteforum.com.
This kit includes the following pieces:
The manual cars will include the templates for your shifter box.
615-896-6100
Retail $199 plus shipping
$145 shipped in the continental USA.
Add $10 for a roll of Foil Tape.
**Upgrade to our Premium Kit when checking out for a $60 savings!**
ORDER HERE
ORDER HERE
This sale is for 10 kits only so place your order now!
Please choose from coupe, Vert or Z06/FRC when ordering.
The C5 Pre-cut Insulation kit comes with everything you need to insulate and provide sound deadening in your Corvette, including Pre-cut pieces for your doors.
Other kits on the market provide a similar product, but do not provide pre-cut pieces for your doors and storage bins, which allow road noise to be present in your front and rear cabin. Our kit gives you everything you need to COMPLETELY insulate your C5 Corvette.
Our kit is a non-fiberglass, non-asphalt based product which weighs in at 3.5 lbs, for those who are weight conscious, it rejects 97% of the radiant heat, and has a manufacturer's rating of 19db of sound and road noise reduction!!! (please see the notes below on this... )
It is only 3/16" thick, so as not to interfere with proper mounting of your panels and seats, and all holes are pre-cut & all pieces are clearly labeled for your convenience.
It is our #1 goal to provide you ease of install, while making a HUGE improvement in your overall enjoyment of your Corvette!!!
Each kit is hand cut to our specifications, and guaranteed to make a dramatic difference in your C5!!!
Each kit comes with the following pieces:
- Driver & Passenger front floorboard pieces, with holes cut for seat bolts and pedals.
- Driver & Passenger side tunnel pieces, cut around your e-brake.
- Full center console pieces, with holes for the center console bolts.
- Driver & Passenger side Door Panel pieces.
- Full Cargo area floor pieces.
- Full Side rear wheel well pieces.
- Full back wall and corner pieces.
- Full Center Well pre-cut pieces.
- Extra pieces for odds and ends coverage that you may need.
Say goodbye to over-heated center consoles, and noisy front cabins!! Our C5 kit is the perfect addition to your C5, and is recommended for every Corvette owner as the #1 modification for their Corvette!!!
Your Corvette will be cooler in the summer, a lot less noisy, and you will regain use of your center console once again.
A lot of research and development has gone into this kit, and we are proud to say that our kit is made to our demanding specs, in house, and cut off of our own templates.
Some have emailed and asked, so here is a picture of the material, as well as some specs on the material itself:
It has 5 layers, and though it is rated at a 19db drop in noise, my customers have tested it in the Vettes at 8-11 db. reduction. Here are some manufacturer specs on it:
polyethylene backing
closed-cell Polyethylene foam
Aluminum Foil
Characteristics | Value | Regulation
Cell Structure: Closed
Nominal Thickness: 5 mm (+ or - 0.5mm)
Steam Permeability: 0.033 gr/m2hkPa ASTM E-96
Noise Insulation: 19dBA IRAM 4063 at 50hz.
Flame Spread Index/Class: 25 or less/ "A" - Class 1 0 ASTM E-84
Smoke Index/Class: 450 or less/ "A" - Class 1 15 ASTM E-84
INSULATION LAYERS
Aluminum Foil polyethylene backing
Aluminum Foil
Pictures of the kit installed in a C5 vert are below.
*Premium Kit*
Upgade to our #1 selling kit today and save $60.
When you want to do all you can to insulate your Vette look no farther!
Two Kits Pre Installed together for Maximum Sound Deadning
- LH and RH Tunnel
- LH and RH Kick Panels (Foil Kit Only)
- LH and RH Under Seats
- Lh and RH Doors
- Center Console and Shifter
- Pre Cut Sections for Manual Shifter Box
- Behind the Seats (Riser)
- Rear Cargo Floor
- LH and RH Fender Wells
- Rear Bumper Wall Sections
- Extra Material to Install in small areas of your choice
- Corner Cubby Compartments
Supporting Vendor
St. Jude Donor '11
The Ensolite was designed by NASA for the space program.This is a very high grade foam/adhesive combination that will handle high heat, is fire retardant just like regular IUO and is stretchable enough for easy install. It resembles a wet suit material. This kit will make a huge difference in heat and road noise while adding only 9lbs to your Vette for both kits.
- LH and RH Tunnel
- Lh and RH Doors
- Rear Cargo Floor
