Brake lights won't work
Brake lights won't work- need new hazard switch
I got pulled over in Houston (super bumpy roads ) yesterday because only my center brake light was working. On Friday they were working... My blinkers work fine still. Is it something at the pedal or a fuse perhaps? Not sure how to troubleshoot this.
EDIT:
I have narrowed it down to the hazard switch. The question now is where to buy the new one? go oem or aftermarket?
EDIT:
I think they are separate circuits.Pretty sure the 3rd brake light is controlled from the module and the others work from the switch located by the pedal.Manual is in the garage or I would look and tell you which fuse to check.
Received 19,289 Likes
'20-'21-'22-'23-'24
Hopefully it is just a fuse. Good luck finding the problem and getting it repaired.
I forgot to mention my hazard switch is finicky, I turned it on a couple months ago and had to bang on it for 5 minutes before I could get it to turn off. Because dadaroo said the normal brake lights go through the hazard switch I imagine I should replace that first?
Fuses are both good.
Last time I turned the hazards on it was nearly impossible to get them off... If I do get the brakes working again after messing with the Hazard Switch I guess I will know what I have to replace.
Edit:
I took a video of my rear lights when I turned the hazards on and off and they only worked intermittently. So I need a new switch.... where should I get that?
Edit:
Here is what I did, just an option. I can now replace the Hazard Switch in less than 30 seconds if I need to.
http://forums.corvetteforum.com/c5-t...elocation.html
