My New StopTech BBK
Old 11-06-2013, 03:16 AM
ktlocklear
ktlocklear's Avatar
Default My New StopTech BBK
Yep....been thinking about it for a couple of months now, and finally pulled the painful trigger on a Stop Tech BBK. My wife (that's right) has tracked our '04 Z since Oct 2012, and has destroyed several sets of pads and cracked several sets of NAPA rotors.....so it was time to upgrade.
I went with the 6 piston front calipers and 4 piston rear calipers with 355mm two piece rotors front and rear. The kit came complete with 3 bottles of Motul 660 fluid, stainless braided brake lines, and Stop Tech Street Performance Pads. For the track, I got a set of Cobalt XR2 pads, front and rear. Install was a breeze. Also, I ordered everything from LG Motorsports. Everything fills the space nicely behind my Speedline 18x10.5 wheels........and the brake performance, all I can say is HOLY CRAP! This is what GM should have put on these cars from the factory.
Anyway..here are some photos...........
Freshly delivered....
Street wheels; 18x10.5 Speedlines.....
Track wheels; 18x10.5 Speedlines......
Wife out on track..pink numbers and all...lol
Thanks for looking
Old 11-06-2013, 07:26 AM
JW Motorsports
Banned Scam/Spammer
JW Motorsports's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
That's a great kit for sure
Old 11-06-2013, 11:30 AM
ktlocklear
ktlocklear's Avatar
Indeed...worth every penny
Old 11-06-2013, 12:28 PM
Adam@Amp'dAutosport.com
Supporting Vendor
Adam@Amp'dAutosport.com's Avatar
St. Jude Donor '11,'13
Looks great.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old 11-06-2013, 12:34 PM
red1vette
red1vette's Avatar
I went to stoptechs last year, and they are amazing brakes---enjoy!
Old 11-06-2013, 01:33 PM
CHJ In Virginia
CHJ In Virginia's Avatar
Congrats on the new brakes --- They will make a substantial difference.
Old 11-06-2013, 01:46 PM
NYZ16
NYZ16's Avatar
They look great.I track my car also and it's on my list next.Good luck.
Old 11-06-2013, 02:06 PM
envyz06
envyz06's Avatar
those look awesome, bet they stop good!
Old 11-06-2013, 02:34 PM
DooDooBear1999
DooDooBear1999's Avatar
Sofa king sick. I wish I wasn't poor and in college so I could afford some new goodies. Do the install yourself?
Old 11-06-2013, 02:56 PM
ktlocklear
ktlocklear's Avatar
Thanks everyone!
Yep....installed them myself. Super easy...
Old 11-06-2013, 03:05 PM
DooDooBear1999
Originally Posted by ktlocklear
Thanks everyone!
Basic removal and replacement or a little more involved?
Old 11-06-2013, 03:29 PM
ktlocklear
ktlocklear's Avatar
Yeah..simple unbolt the old, and bolt up the new....nothing to it.
Only extra step is you have to grind down the lip on the lower ball joint castings on the front to get a minimum of 3.5mm of clearance between the lower ball joint and the much thicker new front rotors. I was less than that, so I just ground the lip down with an angle grinder. Took maybe 3 mins on each front, and now have roughly 5.5mm of clearance.
Here is the install PDF from Stop Tech. It shows what I'm talking about and also the full step-by-step instructions.....
http://www.stoptech.com/docs/install...98-180-1670-04
Old 11-06-2013, 03:36 PM
DooDooBear1999
Well ****. That's easy enough. Definitely something to look forward to in the future. How much of an improvement over the stock system would you rate this as?
Old 11-06-2013, 03:42 PM
joenationwide
joenationwide's Avatar
Oh wow, I am completely drooling.
I love everything about your setup.
No larger radiator or oil cooler though?
Old 11-06-2013, 04:02 PM
ktlocklear
ktlocklear's Avatar
I've only got one track weekend in with the Stop Techs, but it is easily 100% improvement over stock
Old 11-06-2013, 04:06 PM
ktlocklear
ktlocklear's Avatar
Thanks! No larger coolers yet.....only cooling issues I've had have been the high heat trans warning, but only during the peak of summer after about 15 mins into a session. A trans cooler is at the top of my list...hoping to get one before spring
Old 11-06-2013, 07:33 PM
Supporting Vendor
If you want to step up to a better track pad I will be happy to help you.
To My New StopTech BBK
Old 11-06-2013, 08:43 PM
rjwz28
rjwz28's Avatar
About what did the kit run, and from whom?
Old 11-06-2013, 08:47 PM
Support Corvetteforum!
Received 19,308 Likes on 13,979 Posts
'20-'21-'22-'23-'24
Great looking upgrade to your car and if it works better, then that's the important thing.
Old 11-06-2013, 08:51 PM
ktlocklear
ktlocklear's Avatar
Lol, gotta love forum vendors. I'm happy with the cobalts, thanks
Quick Reply: My New StopTech BBK
