9K Racing C5.6 CeliVette Frankenstein Build
#501
I have more to come as well. For those viewing this, can you help me find these parts shipped to Socal or picked up in Socal?
Parts I need for my interior conversion:
C5 FRC Rear Trim Pieces (These 3 pieces)
Mine have at least 1 tab broken on each piece and I don't feel like customize broken pieces that will never fit properly.
If you could help out, I'd appreciate it.
#505
Here is my current list of parts needed till I am finished:
DATE : JUN 18TH
1) s2000 push start button assembly
2) Switch Panel - $120
http://www.summitracing.com/parts/mor-74183/overview/
5 switches
- fuel
- ignition
- fan
- hazard
- ACC
3) Custom Interior
- wrap rear trim pieces (3)
- aluminum door cards plus matching powdercoat with dash
- wrap upper door panel in black leather
- install
4) Yo Speed Custom 9K Door Sills
5) Door Poppers - $90
http://www.ebay.com/itm/80-LBS-Shaved-Door-Handle-Kit-2-Doors-Popper-Solenoid-Remote-Custom-Car-Truck-HD-/201082403868?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ed171fc1c&vxp=mtr
6) Baer 14" 2pc Rear Rotors
7) Custom Brake Lines
8) Gold Brake Caliper Coating
9) X pipe and Custom Exhaust Setup
10) 72" GT Wing - $1,500
http://www.twaymotorsports.com/parts...ette-rear-wing
11) Split Window Hatch - Vinyl cut Decal?
12) Custom Headlights
13) D O N E
14) Custom wood trunk board
15) D O N E
16) Wire in door poppers
17) Install aerocatch 3 rear trunk latches
18) Wire in cluster, dash pieces, climate control extension, tablets, speakers, 3rd brake lights, door poppers, and the rest
19) Install Tail Lights & Brake Light
20) Install Drift ****
21) Purchase (2) 4pt Black Takatas
+ + + + + + ++ + + BODYWORK: + + + + + + ++ + +
Finish Front fenders
Finish Rear Bumper
Install Rear Spats
Finish Sideskirts
Clean up bodywork
fill waves in the roof
+ + + + + + ++ + + FABRICATION: + + + + + + ++ + +
Front Frame Block Off
Better Headlight brackets
Custom Exhaust
Radiator Surround
Finish Dashboard (once interior trim is finished)
Fabricate Rear Diffuser Add-oN Blades
Aluminum Door Cards with tow strap handle
Vbanded filler neck
Shifter Box
http://www.speedhunters.com/wp-conte...a-380SX-31.jpg
Gusset dead pedal
#506
So about 2 weeks, then?
#507
I think the only issue right now is parts. Everything is really coming together. My interior is 60%, suspension game on lock, engine is chill, and just exterior.
#508
So with that list, how far over/under your initial budget are you? What's the total package (not counting the labor, just in parts)?
#511
I'm about 18k right now. I can hit my goal as long as I don't touch the motor.
I see myself hitting the 30k marker once I jump to a ls6 with Itbs.
#512
Nice, that's one hell of a build for sub $20k.
#514
Guess what Santa brought me
Callaway Eibach Pro Coilovers with external reservoirs.Pretty pumped to get these installed. Only downside is that they aren't a true coilover design since these still use the leaf springs.
I've never used or really seen this setup so I am not familiar with it other than it boasts a nasty price tag.
Does anyone have any feedback on this setup? Should I sell them off and go with a true coilover design or use them?
Also how low can I slam my car running these in conjunction of my leafers? I'm looking to enter my car into this year's Sema and don't want it having a thick *** wheel gap.
Also snagged a new intake for $50 bucks. Should make a great replacement from the ebay one that came on the car.
#515
I might be buying a sick bolt in harness bar/back cage setup from a local so hopefully I can land that deal and have it installed by the weekend.
My green takatas were resold to a customer and the black series will just take its place. Should flow evenly with my black and gold interior color scheme.
#517
@3boystoys... I'm guessing you have some type of malware on your system or some tracking cookies that might be causing some slight harm. I'd run an anti-malware software of your choice (there are lots out there, some people prefer some to others). That will probably fix it.
On topic... If I were you, I'd keep track of the hours I've worked on this project. It will probably blow you away when you're finished how much it would have cost.
I'm curious to see all the things you have roll out. It'll be pretty sweet.
For the dash, just an FYI... aluminum & carbon fiber WILL glare of the windshield like crazy (I'd guess even if it was matte). Especially on the top. If I were you I think a mixture of leather/carbon, or leather/aluminum. If you look at the new mclaren p1's dash you can see how the whole thing is carbon, but they use strategically placed alcantara sections to cover. Also, I remember Jeremy Clarkson complaining about that issue with the Alfa Romeo 8C in his special on best driving cars (which the 8c did not win by a long shot).
#518
URL: http://s27.postimg.org/gya55tcmr/image.jpg
URL Categories: Personal Network Storage
Reputation: Unverified
#519
Location: ALL governments are legalized mobsters, so doesn't matter where I live :(
No Malware, very secure PC. It's the location of the pic. Web Firewall is kicking it because of it's location.
