Diagnostic Help Requested By Senior Member
Old 10-02-2013, 01:02 PM
FunFunFun
1st Gear
FunFunFun's Avatar
Default Diagnostic Help Requested By Senior Member
Hello, out there. I have a 2004 Vette with only 37,000 miles. The details are: Initial problem: Battery would drain overnight and car would not start. 2/09/03 > Replaced battery. Same problem. Took to dealer at at cost of $1,200.00. Diagnosis was "600mA draw and traced it to fuse #25 and found IPC causing the draw." "Removed and replaced IPC, programmed, and performed key fob relearn."
Replaced battery again.
Replace OEM Bosch alternator 4/18/13 because gauges would not work.
Now, the problem is this. I start the car. Gauges work and then turn off immediately. I drive the car for a few miles and "check gauges" appears and "low voltage", then gauges work. However, if left sitting for a day or 2, problem reoccurs.
Some charging problem. I know nothing. Tell me what to do now.
Thanks, Ben
Old 10-02-2013, 01:18 PM
JetMechZ16
JetMechZ16's Avatar
There are some very knowledgable people here that I'm sure will chime in to help you. In the mean time You might want to check all your grounds, not just the one on the battery. Make sure there isn't any corrosion and they are all secure.
Also check under the battery and see if the old battery had leaked any acid down below, that has been an issue on some other cars. If it has leaked onto the computer located below the battery that can cause lots of issues.
Old 10-02-2013, 01:22 PM
Evil-Twin
Evil-Twin's Avatar
Received 3,812 Likes on 1,925 Posts
St. Jude Donor '03-'04
Take it back to the dealer, their work is guaranteed.
Old 10-02-2013, 01:58 PM
BOUT X
Corvette Cowboy
Support Corvetteforum!
BOUT X's Avatar
^^^ 1k % ^^^
Old 10-02-2013, 02:03 PM
Corvette_Ed
Corvette_Ed's Avatar
Received 2,843 Likes on 1,801 Posts
It's still 12 months/12,000 miles isn't it?
Old 10-02-2013, 03:55 PM
pewter99
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
hell yeah for $1200 thats the first place I would go
Old 10-02-2013, 03:56 PM
pewter99
pewter99's Avatar
and when you are done find a competent shop in your area that doesn't charge $1200 for that crap
To Diagnostic Help Requested By Senior Member
Quick Reply: Diagnostic Help Requested By Senior Member
