TPMS help, please... Godzilla magnets and no joy
I've got a 03 c5 z06. Today I just paid to have the GM monkey activate the TPMS monitor in my PCM.
I have five sensors in my hand, four of which I intend to install on the wheels and then have tires mounted. I used an 8" speaker magnet and attempted to train the sensors without any success. Suspecting the magnet out of caution, I went to Radio Shack and bought two of the strongest magnets they say they stock. These magnets each measure 1-1/2 x 1/2 x 7/16" and are strong enough to attract each other when they're 2-1/4 to 2-1/2 inches apart on a wooden table top (it's not nearly as slick as a formica top might be). Still no success.
I followed this set of instructions:
I've read through several troubleshooting threads about the subject; I'm pretty sure the magnets are strong enough, but I'll wait for you all to judge that.
When I first turn the ignition on, the initial message on the DIC is:
"Corvette... by Chevrolet" and then the oil temperature is shown (because of course, I have that chosen from the "Gauges" option from the right-side buttons). With the oil temperature displayed, I press the "RESET" button as instructed in order to clear any DIC codes (after the ignition has been turned on). Nothing happens (even when I hold the button down). Is something supposed to happen (or should I wait for something) before I go to the next step and press the OPTIONS button to scroll through to "TIRE TRAINING" mode?
With the exception of complete inactivity on the display when I press the RESET button (to clear any existing DIC codes), everything seems to progress just as the quoted instructions say they should, except that the magnets won't trigger the horn with the display set to "L FRONT TIRE". The display just sits forever, without the horn beeping.
Would someone kindly post a picture of how to hold the magnets against the sensor unit? I've tried to hold the magnet(s) in lots of different configurations:
1) aligned against the stem vertically; with the stem sandwiched by two vertical magnets
2) under the sensor itself (the black side)
3) on top of the sensor (where the badging is)
4) with the sensor sandwiched between two magnets...
The magnets are strong enough that I can move the second magnet without touching it even when it's 'sandwiched'.
Any ideas and advice would sure be appreciated about now.
Thank you!
Turn ON the ignition, with the engine OFF.
Press the DIC RESET button in order to clear any warning messages.
Press and release the OPTIONS button until the display is blank.
Press and hold the RESET button for 3 seconds.
Important
If the DIC does not display the TIRE TRAINING message, ensure the TPM option is enabled in the RCDLR. Refer to Scan Tool Output Controls .
Press and release the OPTIONS button until TIRE TRAINING is displayed.
Press and release the RESET button and LEARN L FRONT TIRE is displayed, verifying the mode has been enabled.
Important
If a horn chirp does not sound after 15 seconds, remove then reinstall the sensor activating tool.
Starting at the left front sensor, hold the J 41760 over the valve stem until a horn chirp sounds.
After the horn chirp sounds, proceed as in step 7 for the next 3 sensors in the following order:
Right front
Right rear
Left rear
Turn the ignition OFF to exit the learn mode.
Important
Important
Right front
Right rear
Left rear
Thank you!
RATS. Nothing's worked...
Thanks very much for your help, Chip and 8Vette7, I really do appreciate it.
I used a FLUKE multi-meter and tested the battery at 12.87 volts; and with the CTEK on it, it measures 14.13 (which is the way it was set up when I tried to set the sensors).
The video helped; I can now see that the RESET button does clear the DIC when I leave the door open and force the "door ajar" message to clear itself.
I re-initiated the TIRE TRAINING/LEARN L FRONT TIRE session 15 times; once for each of the 5 sensors I have, at three locations--from the driver's seat, resting on top of the driver's rear tire, and from against the wall of the 'wheel tub' inside the trunk. I have a small 3" ring magnet and added my two strong Radio Shack magnets to either side of the ring and slid it down the stem as shown in the YouTube video, for all 3 of the sites I mentioned without any success.
Do you think the magnets could be too weak? I can't believe that, but I think the odds are much worse that 5 brand new sensors are all faulty. (They were from GMpartsDirect.com)
I read somewhere that someone who'd had similar frustrations gave up and just mounted the tires with the sensors and tried again after a short drive and supposedly that worked for him.
It doesn't make sense to me, and I'd hate to pay the mounting and balancing costs to find out the sensors won't work.
Any other ideas, please?
Thank you.
Thank you.
Thanks again, Guys.
Yes, they sent the right part; for a 2003, they're AC/Delco 25773946s.
8, I'll try tapping them tomorrow and keep my fingers crossed. It'd be nice if it was that easy. When the roller is "unstuck", can you hear it rattle?
I'm gonna go to the (Goodyear and Firestone) tire dealers tomorrow and see if they'll show me their magnets. Maybe I can gauge the strength of theirs vs. mine.
Received 19,293 Likes
'20-'21-'22-'23-'24
Good luck getting them to program to the car. I had a problem with mine after I put new tires on the car last year. I have programmed sensors before with no issues but these just wouldn't sync. I was even using the GM tool for the programming. Finally gave up and took the car into the local dealership and asked them to give it a try. Tech came out, took his magnet to the car and they sync'd right up. Guess I didn't have the right touch. Only took him a couple of minutes and they did not charge me for the programming.
If all else fails, take it to your dealer and see if they can get it to program.
Here is a couple of thoughts. First, you might try driving for a while and then try to reset the monitors. I have read in some threads they seem to sync up easier after some driving.
Second, it could be a problem with the receiver that takes the signal from the TPM and sends it to the DIC. It also operates the dooor locks from the key fob signal.
I know that places like Discount Tire also have the tool that is supposed to reset them. You could always try there. Good luck. Let us know how it turns out.
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
When I bought new tires and sensors I programed them in the drivers seat with out issue and marked them for what wheel they were to go to. Your magnets should work just fine and it looks like you have the correct sensors.
sounds like you might have too many sensors around and the car is confused by what its trying to learn. Most sensors need to under pressure to learn to the car! The magnet you have should work!
You can have a shop with a scan tool read the sensors to see if they are transmitting?
Why would that be???
Sensors that are not rolling typically are in sleep mode and transmit only once per hour. The magnet is meant to wake them up and force them to transmit. Unless he is holding the magnet to all the sensors at the same time, only the one close to the magnet should wake up and transmit?
Also it is a common practice for the DIY'ers like Mr Bill in post #13 and many others to program new sensors in the drivers seat to verify that they will program befor mounting in wheels only to find out 1 or more is bad.
You are correct! But it sound like we are having problems with that way of doing things. SO to eliminate potential problems which he is definitely haven here. 1. Elemente the old sensors from and around the vehicle. This could interfere with the learning of the new sensors!!!
2. Make sure you are doing the relearn procedure correctly and in a timely manner.
The new sensors could be bad or not transmitting as mickey_7106 said! You can take them to a tire shop and have the sensors scanned with tool and it would tell you if they are transmitting.
This will be the first set of sensors ever on this car; it's a z06 and the TPMS program was only initiated yesterday. That is to say, there are no old sensors around to confuse the receiver, so if there's a transmitting issue, it's only one-way with all 5 of my sensors. Of course I'm only gonna mount 4, but I'm at 100% failure rate... fortunately, I usually do good on the BIG things.
But it's sure aggravating...
"Important
If the DIC does not display the TIRE TRAINING message, ensure the TPM option is enabled in the RCDLR. Refer to Scan Tool Output Controls "
I suspect he didn't really activate them.
If they are activated, they should display the correct message for training. I'd take it back to him since he was paid to do the job.
But when I get it to TIRE TRAINING, then a tap on the RESET key displays LEARN L FRONT TIRE, and that's where I'm stuck.
I 'gave up' and had the tires mounted after I installed the sensors. I'm counting on the sensors needing to be jiggled and awakened (because I missed those two critical posts around the noon hour), so I've mounted the tires/wheels and hopefully they'll respond after a few miles of driving.
Thanks to everyone for your brainstorming and advice; much appreciated!
I had a little trouble training after replaceing 10 year old sensors and new tires. I used a donut shaped magnet from Amazon. Moving the magnet in a small cicular motion around the valve stem worked for me.
Yes, that's all correct. I "misspoke"; I meant BCM, not PCM. I can get the OPTIONS to cycle through to a blank DIC screen segment. From there, holding the RESET key brings up FOB TRAINING (first) and then tapping the OPTIONS key will toggle to TIRE TRAINING and then back to FOB TRAINING (and continue to repeat that pattern as long as I tap the OPTIONS key).
If he BCM is programmed correctly it should give you a tire pressure warning after driving a few minutes.
