cam bearing help
Old 08-28-2013, 04:02 PM
didntdoit11
didntdoit11's Avatar
St. Jude Donor '12
Default cam bearing help
should i replace or is this normal
Old 08-28-2013, 04:52 PM
steveovette
steveovette's Avatar
Not good. Replace for sure.
Old 08-28-2013, 05:23 PM
Mr.Bill
Mr.Bill's Avatar
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Seeing that you are in there I would replace them for sure, They may last for quite a while, But you never know, If the block is out of the car it is easy to do, But if the block is still in the car that is a pain, But can be done.
Just my 2 cents.
Mr.Bill
Old 08-28-2013, 08:00 PM
1BADAZ50TH
1BADAZ50TH's Avatar
You are worn down to the copper, that's not good.
Old 08-29-2013, 07:12 AM
hoosiervette
hoosiervette's Avatar
St. Jude Donor '14-'15-'16
I would replace them also. BTW, how many miles are on the engine?
Old 08-29-2013, 07:28 AM
didntdoit11
St. Jude Donor '12
Old 08-29-2013, 08:08 AM
sfc rick
sfc rick's Avatar
Replace, if it's that worn at 50,000 it's been neglected for sometime. I would also check the rods and mains.
Old 08-29-2013, 12:14 PM
dadaroo
dadaroo's Avatar
You MUST replace!!!!!!!! Now here is the question, why? I am concerned, you need to examine the main and rod bearings too. I would, even if it is a PITA.
Old 08-29-2013, 12:42 PM
Jeff T.
Jeff T.'s Avatar
Received 1,090 Likes on 797 Posts
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Old 08-29-2013, 12:55 PM
OneCylinder
OneCylinder's Avatar
St. Jude Donor '13
I may be old but, I can't imagine replacing a cam without replacing the bearings. That's just asking for trouble. If you replaced the crank wouldn't you replace the main and rod bearings? New bearings are essential for the break-in process.
To cam bearing help
Quick Reply: cam bearing help
