Slight leak! need help! pic
Hey guys, as the title suggests I have a slight water leak. It happens on both side (drivers and passengers) but not as bad on drivers side. I believe it is coming from the being the little ridge in the corner of the door weather stripping in the picture below. I believe water is running over the ridge and into the cabin down the trim and into the floor board.
any help would be great. Would rather not buy all new weather stripping. Ideas welcome
Are you sure it's not coming in via HVAC vent. That's pretty common. There are drain **** (I'm sorry, but thats what they remind me of) underneath on both sides that sometimes get clogged up. You can usually unclog them with just a few squeezes.
Well I think I've found the source of the leak. Looks like its coming in use the window reveal molding. I put rtv in the gap last night in the hopes of sealing it up and may put one more later on tonight. Quick question though, while I've got the entire interior out is there anything I can do and are there any other possible future leak points I can go ahead a rtv?
