LED door switch mod
Old 08-18-2013, 04:38 PM
jcgunn
jcgunn's Avatar
Default LED door switch mod
I did the blue LED door switch mod (also TC panel). I'm not going to do the DIC until I'm in there for some other reason. Looks great, reduces heat, melting of plastic, etc. Had some minor fitment issues, but easily fixed with a file on each of the LED units.
Old 08-18-2013, 04:40 PM
Mr.Bill
Mr.Bill's Avatar
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Looking good, Where did you get the LED bulbs from and part number?
Old 08-18-2013, 04:47 PM
olbear1962
olbear1962's Avatar
Looks great, in for the information
Old 08-18-2013, 05:05 PM
Zr-1Mike00
Support Corvetteforum!
Zr-1Mike00's Avatar
Looking to do the same!
Old 08-18-2013, 05:21 PM
VETJAZZ
VETJAZZ's Avatar
Looks great. I did the same in white and am also waiting to do the DIC and HUD bulbs until I have another need to tear it all apart.
Old 08-19-2013, 12:46 AM
Received 19,187 Likes on 13,911 Posts
'20-'21-'22-'23-'24
Nicely done and looks very good.
Old 08-19-2013, 11:14 AM
KingTut
KingTut's Avatar
Default Fitment
I bought a set from a forum vendor - they had 2 led squares on top - between the size of the leds and the glue to hold them on - I could not get any to fit right and half busted either going in or coming out after not working.
Please indicate more details on where you got them and what adjustments you did to get them to fit right.
Old 08-19-2013, 02:40 PM
jcgunn
jcgunn's Avatar
I just took a flat file to the "barrel" of the plastic between the LED and the "wings" Had to take off about 0.03" Be carefull not to file off the top of the wings.
Old 08-19-2013, 03:51 PM
VETJAZZ
VETJAZZ's Avatar
I got my LED door switch replacements from JWMotoring. Easy replacement. The whole swap took a whole 10 minutes.
http://shop.jwmotoring.com/product.s...categoryId=330
Old 08-19-2013, 04:08 PM
Mr.Bill
Mr.Bill's Avatar
My question is how many bulbs are needed to do both doors?
Thanks.
Old 08-19-2013, 04:29 PM
VETJAZZ
VETJAZZ's Avatar
Thanks.
It takes 6 - 4 for the driver's side and 2 for the passenger side. You pry off the driver's side unit at the bottom and the passenger side from the top.
I removed the old bulbs with the pointed tips of a small pair of needle nose pliers - about a quarter turn to the left. I believe the LEDs are pole sensitive so if they don't work you have to pull them out, rotate 180 deg. and reinstall.
Old 08-19-2013, 04:43 PM
Mr.Bill
Mr.Bill's Avatar
Thank You Sir.
Old 08-19-2013, 05:19 PM
JW Motorsports
Banned Scam/Spammer
JW Motorsports's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Appreciate it and yes they install easy. Those directions we have are key to understanding the mod. Those that run into trouble do so when trying to reverse the polarity.
BTW I do not believe the OP's bulbs are from us. Ours feature 1 SMD which doesn't require any modifications.
Old 08-19-2013, 06:01 PM
MSG C5
MSG C5's Avatar
Received 2,668 Likes on 1,479 Posts
2018 C5 of Year Finalist
So they are pretty much plug and play?
Old 08-19-2013, 06:29 PM
JW Motorsports
Banned Scam/Spammer
Yes they are.
Click that link he posted. We have the directions posted at that link (scroll down a bit).
Old 08-19-2013, 07:10 PM
jcgunn
jcgunn's Avatar
Before you remove the electrical connection on the switch panels, you can check the polarity of the sockets with a meter and mark with a sharpie. I think that all the negatives were inboard and positive were outboard (but don't quote me). Then hook up each LED unit with a 12v supply and test leads and mark each LED polarity. That way they all work right the first time.
Old 08-22-2013, 09:29 PM
Mr.Bill
Mr.Bill's Avatar
I did my 2 doors today and what a difference, I will do the HUD controls and DIC controls as soon as I get more bulbs.
Great Mod....
To LED door switch mod
Old 08-22-2013, 09:33 PM
VETJAZZ
VETJAZZ's Avatar
Great Mod....
Yes, it is amazing!! What color did you choose, and where did you get the bulbs?
Old 08-22-2013, 11:04 PM
Mr.Bill
Mr.Bill's Avatar
I went with blue.
Old 08-22-2013, 11:37 PM
duramaxsky
duramaxsky's Avatar
Quick Reply: LED door switch mod
