c6 GS sways
c6 GS sways
quick question.
would the C6 grand sport sway bars be too much for a base c5?
im getting ready to turn it into half track car half weekend car. im going to put 265/30/18 in the front and 305/35/19 in the rear.
would that be ok? or too much for the car?
would it just ride rough?
and I found this
* C5 Base Suspension: 23 mm-front / 19.1 mm-rear / 3.81mm/2.0mm thickness
* C5 Z51 (97-99): 25.4 mm-front / 21.7 mm-rear
* C5 Z51 (00-04): 28.6 mm-front / 23.6 mm-rear / 4.15mm/3mm thickness
* C5 Z06: 30.0 mm-front / 23.6 mm-rear / 4.5mm/3.5mm thickness
* C6 Base: ?? mm-front / 22.0 mm (7/8")-rear
* C6 Z51: 31 mm-front / 25.4 mm (1")-rear
* C6 Z06: 31 mm-front / 28.8 mm-rear
* C5 Hotchkis: 31.75 mm-front / 25.4 mm-rear / 4mm/4mm thickness
* C5/C6 Addco: 32 mm-front / 25.4 mm-rear
* C5/C6 Addco: 35 mm-front / 25.4 mm-rear
* C5 Pfadt (Adjustables): 32 mm-front / 26 mm-rear http://www.pfadtracing.com/
* C5 Pfadt (Adjustables): 35 mm-front / 28.5 mm-rear (Pfatty)
* C5 T1 (GM Racing): 38.4 mm-front / 27.5 mm-rear / 6.35/6.35 thickness
* C6 T1 (GM Racing): 38.4 mm-front / 27.5 mm-rear / 6mm/?? thick
and I found this
You should be A-OK. Providing you stick with 305 width rear tires.
I actually have a set of front and rear C6 Z51 sways being delivered today! Installation tomorrow... Tail of the Dragon Monday(ish) .
As Mike pointed out, as long as you keep the 305 width rear tires the Z06 bars are the ones you want. If you go smaller than that, or plan to, you might want to look into Z51 bars instead.
