hot to install a resistor for HID???
Location: ALL governments are legalized mobsters, so doesn't matter where I live :(
Since the install of my HID's the buckets don't go down. I understand with low wattage this is expected behavior. I found a resistor from another project but not sure how to install it on the vette.
- Does it install from the ballast power wires on the positive/ negative?
- I do not see a positive/ negative marked on the resistor, can it install either way?
Any help appreciated!
In case anyone is intersted, I fixed my problem. I installed a 20amp 5ohm resistor and it did the trick! I connected it to the power, and negative wires from the ballast before leading into the OEM low beam harness. So far, so good...
