Reset AC
Reset AC
How do i reset the AC the driver side is blowing cold air and the passenger side is blowing hot air i seem to remember pulling some fuse to reset the blowers is that correct
you could just disconnect battery for a bit...
So this is common? Why does it happen?
Mine did it the other day for the first time, except the driver side was hot and passenger side was cold. I rotated the temp control **** on the driver side all the way to HOT, waited a few secs and then turned the **** all the way to COLD. Took care of the issue, and it hasn't done it again since.
Maybe I'm just confused..
Received 19,404 Likes
'20-'21-'22-'23-'24
This might give you some ideas.
