mobil 1
Old 07-21-2013, 11:39 AM
cessna10
cesssna10
Support Corvetteforum!
cessna10's Avatar
Default mobil 1
Are most of you using regular mobil1 or mobil1 ep?
Any thoughts on royal purple. Does anyone know what chevrolet
recommends for the new C7?
Old 07-21-2013, 12:18 PM
NukeC5
NukeC5's Avatar
I use normal Mobil1 5w30.
I hear a lot of negatives when people swap to Royal Purple. Valve train noise becomes louder and gives reason to worry. I'd stay away from it.
Old 07-21-2013, 12:22 PM
jrose7004
jrose7004's Avatar
Received 1,675 Likes on 1,298 Posts
I just use the Mobil 1 recommended for the car.
Old 07-21-2013, 02:04 PM
thmehr
thmehr's Avatar
There as a topic on this before saying the EPA has forced the oil manufactures to cut down on the zinc levels. Mobile 1 has a chart that shows the different zinc levels in its many products. I saw that their 0-40 mobile has more zinc. I tried in my 99 GMC pickup and it has quieted the value train knocking down. I was thinking about using it for my 2000 vert. The 0-40 mobile 1 is designed for European cars and does not have the GM blessing or recommendation. I don't know why.
Old 07-21-2013, 02:12 PM
Daddyrama31
Daddyrama31's Avatar
It's all politics my friend. You can use any quality oil in your vette with no problems at all.
Old 07-21-2013, 02:51 PM
racebum
racebum's Avatar
if there was one oil i would suggest someone not use it would be royal purple, especially in older cars. it's a PAO base which by nature shrinks seals. it's also the same price as redline which is a better oil in every angle and an ester base which actually has a minor swelling effect on seals
mobil1 high mileage is probably the best low cost oil. it's the same price as regular mobil1 with a higher % of zinc and phosphorus which are the main anti wear additives
Old 07-21-2013, 02:52 PM
racebum
racebum's Avatar
api SM and SN are the epa oils and apply to 30 weight with the additive limits
m1 high mile is api SL which does not fall under the EPA neutering
Old 07-21-2013, 02:58 PM
James2002z06
James2002z06's Avatar
Default Yep...
Old 07-21-2013, 04:02 PM
cor28vettes
cor28vettes's Avatar
Received 1,101 Likes on 853 Posts
Only Dexos1 & 2 has the blessing of GM, a trademark of GM
www.gmdexos.com
Old 07-21-2013, 04:25 PM
Mr.Bill
Mr.Bill's Avatar
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I switched to RP years ago and have had no issues at all, I have never read anywhere where it makes the valve train louder, In my case going to RP my engine ran quieter as many have posted. I think the engine even ran smoother.
Just my opinion.
Mr.Bill
Old 07-21-2013, 04:35 PM
cessna10
cesssna10
cessna10's Avatar
Thanks for the help, think i will stay with mobil 1
Old 07-21-2013, 05:10 PM
freew8
freew8's Avatar
Ran Royal Purple in my Avalanche, HHR, Camaro SS and now the Vette. No issues.
Old 07-21-2013, 05:21 PM
madmatt9471
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Straight up Mobil1 10W 40!
Thanks,Matt
Old 07-21-2013, 06:04 PM
baxsom
baxsom's Avatar
as long as it is DEXOS approved any oil will do. There is nothing in the owners manual about any specific brand but considering how cheap the mobil 1 is it wont hurt anything to keep using it. I would bet a months pay that 90% of all oil changes on this site are too early anyway.
Old 07-21-2013, 06:30 PM
DevilDog II
DevilDog II's Avatar
Oldtimer
Switched from Royal Purple to Amsoil several years ago.
Old 07-21-2013, 06:51 PM
racebum
racebum's Avatar
Just my opinion.
Mr.Bill
any oil leaks yet?
Old 07-21-2013, 07:06 PM
James2002z06
Default Mods ....
I stopped with Mobil 1 after changing the crank .....
To mobil 1
Old 07-21-2013, 07:09 PM
dklowrider
dklowrider's Avatar
Pennzoil Platinum and Castrol Edge are held in pretty high regard by oil people. Actually more so than Mobil 1. The problem with Mobil 1 is that while it's not a bad oil, it's not the oil it used to be.
Old 07-21-2013, 07:16 PM
Bent98c5
Bent98c5's Avatar
What do u run now?
Old 07-21-2013, 07:18 PM
racebum
racebum's Avatar
all marketing, those are all highly refined group3 api SM/SN oils
Quick Reply: mobil 1
