Best Mod(s) for Under $500
I am on a budget and I have a mostly stock Vette. I have about $500 to put into my 2002 Electron Blue Coupe. What would you do in my shoes? Cosmetic Changes? Performance? Interior? I'd love to hear your ideas guys!
That said, I'd suggest beefing up the suspension before adding horsepower. C6 Z51 sway bars and metal end links is a good start. The plans for the car will determine the type of shocks to go with. If drag racing is planned, Bilstein shocks are the way to go. The C6 Z06 shocks will work well for road racing or regular driving.
Callaway Honker Cold air intake - $450
Zip tie mod - forget how much it costs but its super cheap
Used catback exhaust in the classifieds section - $500
Lowered on stock bolts - $0
ported throttle body - $75 of free if you do it yourself
Disagree. A C6Z06 bar will work fine and will only be an issue if #1 Turn off Active Handling #2 Drive the car like a under steering FWD vehicle
Received 19,430 Likes
'20-'21-'22-'23-'24
I'd agree with getting a good used catback system - I'd recommend a Corsa one if you can find one for that price. Another good buy would be a Blackwing - can be had for about half of your budget then you could also do something else.
The vendors here who sell them would disagree with you. In fact, they specifically point out that C6 Z06 sway bars should NOT be used unless the car has the appropriate tire width.
