TPMS question
TPMS question
I just put on new Hankooks, love them, great tire. When I got tires mounted and high speed balance done I picked up the car and had the TPMS service in the DIC, I said great, just need to program. When I got home I started the procedure and did not get horn beep on front drivers side tire, so I assumed that my magnet was not very strong. So I went online and ordered a round magnet. Anyway next day I take the car out and no service light and have a reading on all the sensors on the DIC. How does that work? Should I still have the service reading?DIC shows 32 on upfront tires and 30 on rears. Should I go ahead and reprogram when I get magnet? My vette is a 98.
they relearned themselves....do you still have the message? if so hit RESET
Received 19,305 Likes
'20-'21-'22-'23-'24
If you are getting readings on the DIC, the sensors should be working. I'd probably just keep an eye on the readings to ensure they are in fact working properly - check them also with a good air pressure gauge to verify that the pressure shown on the DIC is very close to what you get with a gauge.
only have to reprogram if you get tires mounted and they don't relearn or they get swapped around side to side ..may be a few other instances but thats the main ones
