definitely sold on clay bar process...
Anybody with a silver car have any before/after comments about clay bar? I've never used clay before, but I usually wash my car every couple weeks and keep it waxed, and don't drive it in the rain. After I wash it it feels pretty smooth. Silver cars look clean even when they're dirty so I was wondering how much of a difference clay bar makes on silver (sebring/quicksilver/machine).
Our club had a polishing tutorial from a respected paint guy a couple of years ago. When questioned about clay bars, he totally dismissed them as unnecessary and could ruin the paint! Anyways, after hearing from many many members here about the great results, I tried it a couple of weeks ago. Worked great! Didn't have that much dirt come off but the paint was alot smoother. If the paint feels smoother, you know it's going to shine better too.
If it feels like glass it's going to shine like glass.
Dumb question ... probably!
When I picked the clay bar kit up at the parts store, the guy behind the counter asked me how to use it so I gave him a quick tutorial. My son in law has a nice 350Z vert, and wants me to show him how to use it. I ran my hand across the paint (without a plastic bag) and it needs to be done bad, was rough as a cob.
I roll the clay bar across the hood, say, and it becomes a longer and longer and thinner and thinner sausage. So I pick it up and fold it in half, and knead it a little, and move on to the next square foot, until the whole panel has been rolled. I'm asking because before I tried it I imagined that you would rub the bar along the paint, but that doesn't work because it's too sticky.
The result is great - smooth and slick as glass after waxing,
One more thing - what is the significance of the plastic bag in the quote?
Cheers, Andy
I never had a tutorial and I can't find the instructions that were in the claybar box. So, am I doing it right?
Cheers, Andy
Cheers, Andy
http://lmgtfy.com/?q=how+to+use+clay+bar
Received 3,812 Likes
St. Jude Donor '03-'04
Technically, there is nothing else out there that will grab and pull contaminants that have etched themself into the clear coat, without removing any clear coat. Clay is like a bug guts magnet. If someone has never clayed their car, they are in for a real treat when doing a clay bar job followed by some good polish. Like everything else, the technique used is critical to the final results. Using lots of lube and a light hand works best. For me, claying ( using any brand ) and then a Zaino polish makes my car appear "wet" all the time.
Once you know how to clay your car, you can clay the whole car, one panel at a time. the time invested in claying should be anywhere from 20 minutes to 44 minutes, no more.. a coat of Zaino and the whole job should not take more than two hours,. clay and polish.
Bill aka ET
Bill aka ET
I do detailing as a side job and I can tell you, most people don't know much about the clay bar process but they are amazed at the results I give them when I do their car. I have a 2000 Vette with 145,000 miles, its previous owner kept it outside year round.
Two quick iPhone pictures, its not silver but its close…
Hi there, been A long time for A post. the clay bar, thoughts on the diff grades, thanks Larry. PS my 04 is up to 18600 on the clock.
Received 1,675 Likes
I use clay bar on all of my cars at least once a year.
#34
Where is the best place to buy the Mequiar's
Before you put a coat of wax on your car,use something like Meguiar's No. 9 Swirl Remover, then use Mequiar's No. 205 Ultra Finishing Polish.
When it comes to waxing use Meguiar's No. 21 Synthetic Sealant 2.0 (for dark paint) or Meguiar's No. 26 Hi-Tech Yellow Wax (for light paint).
For maintanance, use Meguiar's No. 34 Final Inspection. I actually buy this product by the gallon.
You will appreciate the results.
I was taught this method by Jim Larson, Meguiar's head detailer.
Hope this helps.
Roger T
Hope this helps.
Roger T
Thanks,
Dave
#35
Absolutely! Makes a huge difference.
Ohhhhhh brother. Its not a rolling pin hah.
The kits usually come with the spray detailer (Lubricant for the Clay) Usually 2 Grams of clay, and a microfiber towel. Additional items I make sure I have are a plethora of microfiber towels, MUSIC, and a nice cold beverage... or 12...
In short (hopefully) the process I follow goes like this....
Step One: Wash the car (With CAR WASH 1st)... 2 Bucket method. Then a 3rd bucket for wheels and tires.
Step Two: Empty one bucket and rinse/clean out the wash mitt and bucket and then use DAWN DISH SOAP. This will take all the previous wax/polish off the car and take you down to the clear coat. Make sure you rinse the car very well after using the dish soap.
Step Three: Dry quickly and remove all water.
Step Four: I start with HALF the hood and work all the way around the car. Spray a liberal amount of the speed detailer over about a 2' x 2' area... kneed the clay and rub in straight lines back and fourth across the lubricated area... Spray more detailer as needed. You want to try and not have the clay hit a dry spot. Usually leaves a bit of clay which you have to lubricate and rub to get it off. No big deal.
Step Five: Apply Micro Polish/Swirl and Haze Remover of your choice. I use Adams or Zaino Z2. (I also use a more "abrasive" applicator pad with the polish step)
Step Six: Apply a coat of the wax of your choice. I use Zaino Z5 Show Car.
Step Seven: Step back and enjoy the shine! Snap a picture or 100 and go drive and show off it off (What I do)..... Or cover it
Hopefully that wasn't too painful, and helpful to those who have not done the process before. This may not be the way others do it however this is what I find to be a pretty darn good way of doing it.
Lastly the cellophane plastic sandwich bag is used to show just WHY the car needs to be clayed. Put your hand in the bag and rub it across the surface... Should feel rough and contaminated. Clay a small area and try the bag again... There you have the answer to why clay is so important!! Should feel smooth as glass!
(Before I used the Zaino...)
Just how wet does that look!?? Once you clay you never go back!
Cheers, Andy
Cheers, Andy
#36
I tried claying for the first time this year. Practiced on my daily driver and then did my C5. I was amazed at the results. Check out Adams Polishes. The products are great. He also has a bunch of instructional videos on his site and on youtube.
http://http://www.adamspolishes.com/p-37-adams-detailing-clay-bar-kit.aspx[/URL]
#37
Oldtimer
