Line lock solenoid fail and lock brakes without power
Old 06-19-2013, 10:36 PM
nullpointer
nullpointer's Avatar
Default Line lock solenoid fail and lock brakes without power
I have a line lock on my 02 z06 and right now the front brakes are locked on. I just finished bleeding the brakes at all 4 corners but now the car wont move. The rear was jacked up and they spin freely. The line lock was previously disconnected but when reconnected blew the 30a fuse. Tried a 25a fuse since I didn't have a 30 and it blew too.
BUT if the line lock has no power why is it locking the brakes? Bad solenoid?
Old 06-20-2013, 09:05 AM
nullpointer
Going to get a new 30a fuse today, hook back up the switch and send power to the solenoid. If it pops the 30a fuse I'm going to assume the solenoid is ****. Any other suggestions?
Odd because the brakes bleed fine
Old 06-20-2013, 10:33 AM
Mr.Bill
Mr.Bill's Avatar
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Sounds like you have a shorted/Frozen solenoid and it is not releasing. Hence the fuse blowing.
Old 06-20-2013, 10:37 AM
nullpointer
thanks, I was leaning that way but didn't know in what way they would fail. Worst timing too, I am going to try one more fuse to try to get it to open. Then I will bypass it with some brake line until I can get a new solenoid.
It's odd too because the line to the solenoid for the voltage beeps as grounded when I test with my ohm meter. I checked wiring and nothing is pinched or crimped, so it must internally be ****ed It should pop this fuse fast then
To Line lock solenoid fail and lock brakes without power
Quick Reply: Line lock solenoid fail and lock brakes without power
