A/C, can you overcharge it!
My dual zone a/c is getting warm on the drivers side and from what I have read it needs a refill or topped off. Is it ok to just go to a auto store and get the proper freon and top it off until it gets cold again? I know little about HVAC but it seems that the small can of freon would not have enough pressure to overcharge the system if that is possible. I have done it to my daily beater and it worked fine. Any suggestions? I hate taking it to a repair shop and have people crawling in and out of it.
I had the same problem last year. Buy the unit that has the refrigerant and the guage built in, Follow instructions and you will know when its charged. AC overcharging can damage the system................
Thanks, I will do that. Do you have to recall the lbs. when it is full? Seems I read it is full with only 1 pound of freon.
Gimme a break....I'm working on about three hours of sleep. Coolant. Refrigerant. Whatever. The stuff that makes it blow cold; and I did specify R134 so quit the nit picking. I'm pretty sure everyone knows what I was referring to.
(1) Yes you can overcharge it.
(2) Have you even checked the codes on the DIC, see the HVAC codes then get back to us. MAKE SURE YOU WRITE DOWN THE CODES BEFORE CLEAR THEM!
http://www.stengel.net/diccodes.htm
(3) It is a known problem that the Actuators will get out of sync and end up doing what you are experiencing
http://forums.corvetteforum.com/c5-t...tuators-2.html
(4) You can reset/clear the codes from the HVAC and see that it will cycle through the actuators, try this and see what happens.
Let us know what you find!
Thanks,Matt
Thanks,Matt
Thanks,Matt
Thanks,Matt
Thanks, I will check it out this weekend. However from what I read it is actually possible for the system to be low yet still blow cold on the passenger side of the car. Two guys got in a heated argument about it and it turned out from what I understood that yes it is possible with low refrigerant. I googled it and it think it a post on here from way back in 02 or something.
This would make sense if A/C wasn't a part of most of the cars manufactured today (anyone know if Cali still gets cars without A/C?). They're not Corvette-specific. Neither is the R134.
Get over it already Mr. A/C-Term-Police.
Oh, I get it. In your mind, because a certain type of machine has existed for a long time it means youngsters who are learning about that machine will automatically be instilled with the correct terminology concerning that machine. Uh huh, yeah, that makes perfect sense. Ya know, this might even obsolete crystal ballz!
You really need a hobby.
BTW...The R134 in the cans can be bought with the sealant in them. If you have a small leak, it will likely seal it.
It's a cryin' shame when individuals prefer to revel in mistake rather than stand corrected.
Added:
You youngsters are free to consider the terms refrigerant and coolant as being synonymous. At least try to understand that the stuff you put in HVAC systems never used to be correctly referred to as coolant! Coolant always used to refer to the stuff that went into engine cooling systems. Man up - accept the fact that to old fartz like myself there is an important difference between coolant and refrigerant whether you prefer to recognize that difference or not.
Added:
