1997 drivers window makes noise when moved
it sounds like there's a lot of dirt on the track or something. I have the panel off, window out, and I sprayed some silicone one on the tracks and it still makes the noise. any suggestions? also it sometimes doesn't roll all the way up ( about an inch short) any suggestions? thank you!!
Make sure the cables have good tension on them. I had a similar problem (from the sound of it) - grinding noise whenever i rolled up/down the window, sometimes stopping short. Noticed one of the cables was very slack, secured it behind a clip with a zip tie to hold tension on it.
Not 100% sure if it'll work for yours, but it's cheap and easy to try
the one going to the bottom of the left track is already zip tied. I'd assume someone has already had trouble with it. I held tension on all of the other ones whole rolling it and nothing. is there anything to do other than drop $150 on a new regulator?
There are the only pictures i managed to grab when I was working on mine - couldn't really get a good angle on it inside the door
The green circle highlights the area where I attached the cable, behind the plastic cover.
figured it out!! one of the steel cables started to fray. half was stuck in the motor, half was on the track. I cut out the frayed part but it still needs to be replaced. now the truck is to find some cable without the whole assembly!
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Mr.Bill
that must mean there's no chance of buying just the steel cables.. eh? haha I can't find them online and had a buddy that works at O'Reillys look for them. I found a Delco for $150. anyone know of any better prices?
