[PROCEDURE] How to blow out your A/C Condensor and Engine Radiator
#41
Great write up. I estimate you have saved me a couple of grand over the last couple of years using your site instead of my "old" mechanic. Fun to do as well. Thanks a million for the new and old info.
#43
Christee:
Give me your HVAC, and I can fix it easily. I'm in Wylie.
We meet in Plano weekly for our Corvette GTG on Sunday evenings.
See here...
http://forums.corvetteforum.com/sout...area-18-a.html
Toque
See here...
Toque
#44
I'm no pro for sure, but when I learn something I like to post it up !
I'm glad to hear some find it helpful.
Toque
#49
They were on sale at Harbor Freight today, $3.99
Picked one up, modded and used it today.
#51
A little more info would be appreciated
I have been reading your write up on how to clean between the radiator and condenser. My car I just purchased has been getting up to 220 rather easily, and then it starts to burn oil. So I am thinking your procedure will work wonders for me. I have a compressor, but you said about being aware of the pressure or you will bend fins. What pressure did you use? Also, for that blower you used, how long was it? I live in Canada, so I don't think where you said you got it applies to me. Any help is appreciated.
#53
think its possible to use water instead of air with a modified nozzle similar to the one the OP uses? (don't have the cash for a compressor right now)
sorry if this has been asked already
#54
I also put some cardboard between the radiators when I was cleaning the rear radiator. That way I did not blow crap into the front radiator.
See this post ... #20
http://forums.corvetteforum.com/c5-t...-radiator.html
Toque
#55
I'm sure you can order one from Canada.
They are not expensive.
http://www.harborfreight.com/air-blo...ion-68257.html
Toque
#56
Surprised this question didn't come up more often. And the solution is from, you guessed it, Harbor Freight:
http://www.harborfreight.com/tubing-bender-3755.html
Only $6.
Only $6.
#57
Only $6.
Only $6.
Toque
#58
So I did it this morning
However, I still see some stuff in the rad and condenser. As you can see that is a lot of stuff, my car has almost 50,000 miles on it, and it was well plugged. Should I go to water next? I use a little more psi than 50, didn't bend any fins. however, I only have a 7 gallon compressor, so its not like it maintains excellent pressure. No doubt it sure helped, but I want to get it all out. It was only about 70 degrees out this morning, and the car still went past 205, but not to 225.
#59
Thats a lot of crap !
Sure makes a mess in the garage huh ?
I would try the water as well.
It can't hurt. Just try to keep the water away from any electronics.
Sounds like your on the right path though !
Toque
Toque
#60
Thanks again for all your help Toque, you are a wealth of information, especially on your website. I hate to be a pain, but I am going to send you a pm on another issue I am having, maybe you have some insight on it, as I can't find any one else in this forum with a thread regarding what is going on.
